Old 3rd November 2004, 05:05 PM   #1
PWatts is offline PWatts  South Africa
Default highpass amp strategy for active system?
Hi everyone,
I'm in need of amplifier advice. My new active speaker setup consists out of 2.5way monitors with Peerless XLS12 subs. Since the monitors are actively highpassed (2nd order @ 55Hz), my 300W Leach superamp is definitely overkill for powering them. (The mid-tweeter crossover is still passive)
A lower power, higher quality power amp of around 50W should suffice, and naturally class-A comes to mind. After hearing a friend's Aleph-X's, I was totally smitten by its sheer quality and dynamics.
A lower-power version with less output devices and reduced voltage rails should suffice, but I'm concerned about its balanced operation. My preamp (DIY AudioNote M7 tube) and active crossover is single-ended, which will be a problem with the AX's symmetrical topology.
What would you guys recommend? I can add a balanced line driver after the crossover, but 3 separate stages (preamp, filter, driver) between source and amp starts being redicilous, unless I convert the signal to balanced _before_ the crossover and completely rebuild it for balanced operation. Or would it in this case be better to rather use an amp that's more OK with single-ended inputs like an Aleph5?
Thanks,
Pierre
Old 3rd November 2004, 06:43 PM   #2
The one and only
Nelson Pass's Avatar
The X circuit is perfectly happy with a single-ended input - it
just treats ground as the - input and amplifies the difference
between it and the + input. You definitely want to ground the
- input, though.
My New Active 3-Way System wigginjs Multi-Way 15 26th October 2009 08:06 PM
My DIY 5 Way Active Horn System KCCT82 Multi-Way 25 25th April 2009 06:02 AM
Active highpass filter - ground skogs Analog Line Level 3 19th June 2007 06:25 PM
active system, first pictures aaronboumans Pass Labs 39 11th July 2005 10:40 AM
possible active system bonsai171 Solid State 5 13th July 2004 03:41 AM
Page generated in 0.06866 seconds (69.58% PHP - 30.42% MySQL) with 10 queries
