Old 16th July 2002, 09:27 AM   #41
Nickolas K.'s Avatar
Default Why balanced?
I don't know much about electronics.
But if i'm not mistaken the aleph amps are class A single ended designs.
Why should the preamp or the AXO be balanced?
Is there a real advantage there?
I have no experience with balanced designs, i have never used one in my system.
What are the sonic benefits of balanced operation?
Thanks,
Nick
Old 16th July 2002, 10:15 AM   #42
Warp Engineer
On Holiday
AudioFreak's Avatar
balanced interconnects minimise hum and noise pickup and if the signal path is balanced back to the source, also minimise timing noise and other unwanted spurious signals by virtue of differential cancellation....
Old 16th July 2002, 10:27 AM   #43
Default Audiofreak,
I understand, but isn't there also a negative effect due to the extra active devices added to the circuit?
Thanks,
Nick
Old 16th July 2002, 10:48 AM   #44
Warp Engineer
On Holiday
AudioFreak's Avatar
as far as line level goes, the gains outway the negative effects which equate to practically zero in this case. Make sure you do not confuse balanced with push/pull operation, I generally prefer balanced single ended circuits.
Old 16th July 2002, 12:00 PM   #45
Super_BQ's Avatar
Send a message via ICQ to Super_BQ Send a message via Yahoo to Super_BQ
Default On Topic
Let's not get off topic guys (:
Old 16th July 2002, 09:18 PM   #46
The one and only
Nelson Pass's Avatar
As you would surmise, my children are named SoP and
SoSop
Old 16th July 2002, 09:55 PM   #47
Default SoP
VSOP comes to mind, you know that special kind of brandy.
Old 25th September 2002, 06:34 PM   #48
jag is offline jag  United States
Some information, on what appears to be the Claw jr, extracted from the XVR1 ELECTRONIC CROSSOVER NETWORK OWNERS MANUAL:
Real Project #2
"This is a much more complex system. It has twin 21 inch subwoofers mounted in a 12 foot long transmission line, a 12 inch woofer for midbass, a 5 inch midrange, and a ribbon tweeter. This system will be quad-amped."
"And there we have it, a quad-amped loudspeaker with a response +-5 dB from about 18 Hz to 40,000 Hz."
Wow! My appartment does not even have a ceiling 12' high
A great manual by the way - highly informative about crossovers - a must read! A big thanks yet again to 'the one and only' for making all this information freely available.
Old 25th September 2002, 07:33 PM   #49
Send a message via MSN to Tazzy
SoSop
Would have thought that your kids would be SoP en DoP?
And even BoSoP or SoSoP or BoDop or..... AHhhhhh
Lemme ask what my girlfriend thinks of SoT or DoT
Old 25th September 2002, 08:09 PM   #50
The one and only
This is not Claw Jr., but rather an interim woofer project
named "El Pipe-O" to be released shortly.
Page generated in 0.10360 seconds (79.57% PHP - 20.43% MySQL) with 11 queries
