DIY progress report
DIY progress report
Old 18th March 2017, 10:09 AM   #2331
R.I.P.
you are trying to find out why the voltage starts to drop.
So go back to the start and test in stages.
You need input AND output voltages so that you can check that the transformer is giving an expected output.
And you can leave the Tester in circuit because the current draw is near zero (the leakage through the smoothing caps when you attach them).
regards Andrew T.
Old 18th March 2017, 02:37 PM   #2332
Juntuin is offline Juntuin  Finland
Ok, now were getting somewhere. I must have some kind of problem with my measurings earlier or my old & cheap multimeter; i made several measurements now and there was no decreasing voltage!
Input from wall: 230v
Output from transformer: 2 x 31v
After bridge rectifier: 28.4v, both same
Rails: +/-42.4v
Final stupid question, but i have to be sure..measuring rail voltages:
Multimeter black wire to ground, red wire to positive lead (42.4v). Black stays grounded, red wire to negative lead (-42.4v).
Multimeter red to positive lead, black to negative lead (84.8v).
Sorry for these newbie questions, as i said; this in my first amplifier project and it feels kinda hard time to time, so much learning and nothing with my language. Next one will likely to be much easier!
Oh, btw! I heard that these PCB:s are not "authorized" by mr. Pass, is this correct? It's definetly not too late to change plans if so, and make another Pass amplifier if there is any version that accept my existing psu?
Old 18th March 2017, 03:03 PM   #2333
R.I.P.
Rails: +/-42.4v
this looks good.
...........measuring rail voltages:
This confirms your measurements are good.
You measured 230:31Vac.
this is the unloaded voltage from the secondary. You probably have a 28Vac transformer. That's the voltage when the all the secondaries are delivering their rated currents, simultaneously.
............... I heard that these PCB:s are not "authorized" by mr. Pass, is this correct? It's definetly not too late to change plans if so, and make another Pass amplifier if there is any version that accept my existing psu?
Did you buy them from N.Pass?
If so then they are "authorised".
If you bought fakes/clones from a crook selling someone else's IP, then you can't expect any support from N.Pass.
regards Andrew T.
Old 18th March 2017, 03:17 PM   #2334
this looks good.This confirms your measurements are good.
Great, thank you!
I got these PCB's second handed. Hmm, i have to study a little where and what i could get to replace these. I guess rail voltage is kinda high for most Pass desings.
Old 18th March 2017, 03:37 PM   #2335
R.I.P.
Most Pass designs are ClassA.
Expect the transformer VA to be between 6times and 10times the maximum ClassA output.
i.e. a 50W+50W ClassA stereo amplifier would need a minimum of a 600VA transformer and may perform better with a 1000VA transformer of the correct voltage.
regards Andrew T.
Old 18th March 2017, 03:43 PM   #2336
I know, that's why i have these huge heatsinks also one pair of 545VA toroids, so monoblock build it is..
Old 19th March 2017, 09:49 AM   #2337
R.I.P.
545VA allows from 55W of ClassA to 90W of ClassA
42Vdc will drop down to ~+-38Vdc when biased to ClassA
That would give you >>90W into 4ohms
or around 70W to 80W into 8ohms.
Your transformer is fixing your output into an 8ohms speaker with a maximum ClassA of around 75W
Output bias would be >2.1A and dissipation will be ~160W
This is well beyond a standard F5.
Have a good read of the F5 and F5t to see if these are what you want.
I don't know tha Aleph range.
regards Andrew T.
Old 20th August 2017, 03:02 AM   #2338
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
DIY progress report
all PCB's in the diyAudio Store based on Nelson's IP are authorized by Nelson Pass. In fact that's one of the few places to get them.
[QUOTE=Did you buy them from N.Pass?
If you bought fakes/clones from a crook selling someone else's IP, then you can't expect any support from N.Pass.[/QUOTE]
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 17th January 2018, 10:46 PM   #2339
woofertester is offline woofertester  United States
Default ADCOM GFA 555 redux?
I just finished reading this thread from start to finish. Did the ADCOM GFA 555 re-design every happen? I have two of them. One looks to be either an amateur mod or a hastily hand-built early factory unit.
It would be sweet to have a modern NP updated design inside.
DIY progress reportHide this!Advertise here!
