#2301 |
#2302 |
Fortunately these jFETs are manufacturer in a virtually symmetrical layout.
The D & the S can be swapped and the device will probably operate the same way. With the dgs PIN out, you can insert these jFETs back to front and the circuit should still operate normally. It's the ones where gate is not the centre PIN that cause build problems. |
#2303 | |
![]() looks good ,but I would change the Parts number to match ,R1=R1 ,,,It gets confusing if you look at another schematic or if you do mods, |
#2304 |
any informtion aboout NP's input on adcoms 555 amp in relations to the 555ll?
