#1781 |
Paper mache horn fabricator
Cool! How do you adjust all those pots?
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com |
#1782 |
The one and only
With a little screwdriver.
(snicker) OK, the default values are midway, and you can tweak the values to taste. |
#1783 |
(snicker) good-one!
#1784 |
Screwdriver + carbon pot = Hi-Fi cocktail
(titter) (Next up will be the coil winding contest for the inductor in the LCR)
Not so much,.......if it says "ZM" in the corner. |
#1785 |
(chuckle)
#1786 | |
Great!! Ok, I see that 25 K pots are for frequency adjustment, while the 10 K one looks like a notch filter... When the buffer article gets published, it should be fun to play with its implementation... Thanks!
#1787 |
The one and only
Part 1 is intended just for buffers, Part 2 for applications.
#1789 | |
First just the wheel , then comes the car.
#1790 | |
If it works anything remotely like the way I suspect, you'll see it as an active circuit. Grey |
