Old 27th December 2005, 06:12 PM   #1021
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
Good idea Moe. This would probably spur me on to build me a preamp. A jfet BZLS would be very nice indeed.
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
Old 27th December 2005, 09:19 PM   #1022
Can it be done?
Yes.
Will it be done?
Yes.
I have cobbled together a number of things on the bench and scratched more out on paper. They will appear in due time. Nelson will, no doubt, put out ten or twenty projects over the next six months. Others will also do things, given time and devices to work with.
Grey
Old 27th December 2005, 09:23 PM   #1023
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Wow! That's great to hear.
I'm looking forward to seeing the update / evolution of my favorite
PassDIY project.
The JBZLS could be a giant killer
Old 17th January 2006, 05:14 PM   #1024
steenoe is offline steenoe  Denmark
steenoe's Avatar
Yeah, I have been thinking something along those lines also. I wonder what it would take to use those J-fets in the BosoZ? Its easy enough to find out if they work in there without modifications of course. (Thats the approach I would take, being a rather reckless DIY'er!)
But I am not sure at all that its the best way to go! Lots of us wants to know about this I am sure. Several DIY'ers asked me about that particular question, but as you all know by now I am a really lousy designer, but pretty fast when it comes to construction
Well as it stands right now, I will just pop a few Lovoltechs into one of the BosoZ boards I have and see how it goes A little advice would be really appreciated though
Steen
Old 17th January 2006, 06:49 PM   #1025
moe29's Avatar
maybe there isn't the same amount of improvement using JFETS in
this application (BZLS)... who knows? I have no idea.
...maybe Mr. Pass or someone else could give us an idea
Old 17th January 2006, 07:03 PM   #1026
steenoe's Avatar
who knows?
I note that the capacitance of the J-fets is linear! That alone should make an improvement over the mosfets?
Steen
Old 17th January 2006, 08:25 PM   #1027
metalman's Avatar
The lovoltech's have the necessary power rating, but their Vds(max) is only 24V, so you would need to either lower the positive rail or cascode them to keep them alive. Otherwise it doesn't look like much alteration would be required.
Does anybody know what the noise figure is for these devices, I was just looking at the datasheet didn't see it. I did see the capacitance and gate charge specs, and the IRF610 vs LU1014 are comparabel on the gate charge specs, but the IRF610 has much lower capacitance ratings. The other issue that concerns me for use in a BZLS is the gate current levels which look a little high for a typical source component to properly drive.
My 2 cents after a very brief look.
Old 17th January 2006, 08:54 PM   #1028
steenoe's Avatar
Thanks Terry I noticed that the IRF devices had much lower Ciss (input capacitance) but since the J-fets are linear in that respect, maybe there would be a way for overcomming that?
Steen
Old 17th January 2006, 09:46 PM   #1029
gl is offline gl  United States
The first F3 prototype used mosfets and was moved over to using Lovoltech JFETs somewhere late in it's development.
The F3 appears to use 1) a voltage regulated PS, 2) a constant current source supplying the gain device(s), 3) a cascoded gain device which makes Vds almost constant and greatly reduces the effect of the non-linear input cap, and 4) the cascode device is modulated to further reduce distortion.
The question I have is how many of these belts and pairs of suspenders were in place when the switch from mosfet to jfet took place? I mean if you truss up your gain device to this extent how much different can the two device type sound?
The F3 is clearly a magic sounding piece judging from the reviews. But how much of it is the JFETs and how much is NP's skill at creating a first class context.
I am not trying to rain on the parade. I'm just as enthusiastic about these new parts as anyone else. But I do wonder. I can't help it.
Graeme
Old 17th January 2006, 11:46 PM   #1030
Guys, bear in mind that these parts weren't designed with us in mind. As so often happens, we're taking the scraps from the table; accidental beneficiaries of other technologies.
Noise? Whuzzat? These things are supposed to be used in computer power supplies. They could care less about noise. According to my contacts at Lovoltech, they had never considered linear use in any context, much less audio. They were designed as switches. It's quite accidental that they have any application in audio at all...unless you were thinking of building a switching power supply. (Even then the voltage would be pretty low.)
Me? I take scraps and smile. It's rare that anyone actually designs a part with audio in mind.
For those of you about to protest and list off a few Motorola/Toshiba/Hitachi devices, note one thing before proceeding: Those linear devices are/were also used in the driver circuits for mainframe hard drive voice coils. Ask yourself which is the bigger market. Would we (meaning audio folks) have gotten half the parts we now have if it weren't for crossover uses in the computer or medical industries? With the demise of the large disk drives--now replaced with monster RAID arrays like the Hitachi 9900V behind me--an important (to us) market sector has been lost. Given the size of the audio market (rather small in the overall scheme of things) and the slow trend away from linear to class D amps, it is entirely possible that our future depends on such 'accidents' as the discovery of a linear region in the Lovoltech LU1014D.
Grey
Page generated in 0.20219 seconds (50.94% PHP - 49.06% MySQL) with 11 queries
