I'm currently building an Aleph 4 with many expectations. Does it really sound so different compared to other amps? (What a great forum!) I have in stock 2 times 500VA 2x35Vsec transformers and want it to use it in this schematic (see picture)[IMG]D:\Documents and Settings\Prapper1\Desktop\experiment.jpg[/IMG] Is this OK? The heatsinks that i'm planning to use has got a size of 32cmx30cm per each channel wich comes around 960 square centimeters. Mcfinnis has got 1060. So I think I come pretty close! Thanks in advance Remco |
#2 |
Sorry, I forgot to post my question...
Should this schematic work? Or should i go for one 1KVA transformer! |
#3 |
The one and only
Assuming to get about +/- 50 volts on this supply
it should work, but the transformers will be running close to their ratings, and will get hot. Worst case? They fail after some time. |
#4 |
Thanks Mr Pass!
So should go for 1 peace of 1KVA! (then I'm having trouble with space) I'll figure something out... Any other solutions? I've got spare space of 6.6cm by 30cm just enough for 2X500VA. The fahrads is hopefully enough! Give me your opinions! I love it! Thanks everyone! Remco |
#5 |
Hi Remco,
you could always use PSUdesigner for these kind of questions Itīll give you very good figures for all the currents/voltages in your supply. With these caps and chokes you should get around 10-20mV ripple @ 3A. (donīt have the link at the moment though )william
een ooievaar is geen konijn want zijn oren zijn te klein! |
#6 | |
Mine 1000VA 40-0-40 with 88000uf with a 250W load gives about +49.2V ... I hate to think what happens when you load 2x500VA 35-0-35 with 500W ... Edwin |
#7 |
So the original Aleph 4 uses also 2X 1000VA transformers?
I thought it uses only 1 transformer according to other threads. Can anyone post some inner pictures from the original Aleph 4? Thank you, Remco |
#8 | |
Warp Engineer
On Holiday
#9 |
I read that the rule of thumb for sizing transformer is 7.5 times that of amplifier output. So, for 100w/ch, you'll need at least a 750VA transformer per channel.
#10 |
Warp Engineer
On Holiday
That is very much an idealistic situation in practice you dont 'need' anywhere near 7 or even 3 times the power draw but if you have the space and the money, it certainly doesnt hurt to get a transformer spec'ed for a much higher power rating.
| experimental class D | fokker | Class D | 0 | 29th December 2006 01:59 AM |
| My experimental speakers :) | quickshift | Multi-Way | 18 | 6th November 2006 01:44 PM |
| R29 in Aleph4 | ja | Pass Labs | 1 | 5th May 2003 09:26 PM |
| Relayed Help on Aleph4 | mefinnis | Pass Labs | 2 | 14th October 2001 11:35 AM |
| Aleph4, caps ? | victor | Pass Labs | 1 | 4th August 2001 12:45 AM |
| Page generated in 0.13878 seconds (73.13% PHP - 26.87% MySQL) with 11 queries |
