Old 12th December 2002, 03:44 AM   #41
fcel is offline fcel  United States
Brian ... this is the thread about the step attenuator New High-quality Attenuator ...
Old 12th December 2002, 05:44 AM   #42
JDeV is offline JDeV  South Africa
Default Stepped attenuator vs POT
If I may ask these questions re the same subject:
1.) What are the advantage of using a stepped attenuator in place of a POT ?
2.) If I can only get a 10k for P3/P4, must I change value of R11/R12, if so what value?
3.) Is it O.K. to use 10k instead of 5k for P3/P4?
(All these for BoSoZ)
Thanx
"Be carefull who's advice you buy, but be patient with those who supply it."
From Baz Luhrmann's - Everybody’s Free (To Wear Sunscreen)
Old 12th December 2002, 10:46 AM   #43
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
1.see www.dact.com
2.no
3.yes
Mads K
Old 12th December 2002, 11:33 AM   #44
Originally posted by BrianGT
question:
Would anyone be interested in this?
Brian
Hi Brian,
I am definitely interested. And many thanks to you
and your roommate.
Dennis
Old 12th December 2002, 11:57 AM   #45
protos is offline protos  Greece
protos's Avatar
Brian,
I am also interested in your suggestion.
Old 12th December 2002, 07:18 PM   #46
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Brian,
I think a kit is a great idea, with costs savings for everyone.
I think you should offer it as a parts kit with a burned and tested chip, and as an assembled item with only resistors missing.
Something like the John Pomann kit:
http://www.snippets.org/filters/crossover.htm#details
I also can't imagine anyone complaining if you add a bit of profit for you and your roomate, since it will be a LOT of work.
Others will confirm that just mailing out PCB's like you did before is a hassle. Add assembling and testing, and you will need to be reimbursed. The value of this kit is pretty exciting- lots of volume steps, readout, remote, etc.
It addresses a lot of issues the DIY preamp (son of Dork) was concerned with. Perhaps the DIY preamp people can concentrate on the audio circuit, and use your board as the controls.
Maybe in the future you could add slave boards for multi channel/ biamp control, and remote input select. At the moment a stereo, self contained board that can be connected into the circuit as easily as a stereo pot, sounds perfect
Old 12th December 2002, 07:34 PM   #47
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Originally posted by Variac
Brian,
Alright, I am currently talking with my roommate and we are trying to decide if this is going to work, and the best way to implement this. I will make a seperate thread for this in a bit, for suggestions and ideas for carrying this out.
The whole issue that I am not sure about now is cost. The version that I have been planning on making for myself will cost about $250 (with out chassis), since I am using a $100 vfd, and a $50 optical decoder. I am going to integrate this into the same chassis as my bosoz.
Brian
Old 12th December 2002, 07:59 PM   #48
BrianGT's Avatar
I am making an new thread for this now:
Relay-based passive volume control project
If anyone is interested in this project, please express your interest and comment on your opinion of the features and what you expect from it.
Brian
DIY stepped attenuator Shoog Tubes / Valves 5 6th July 2008 09:58 AM
Stepped attenuator sonokeling Parts 0 11th July 2006 09:05 AM
Stepped Attenuator officeboy Parts 3 6th May 2004 03:32 PM
Resistor values of stepped attenuator for BoSoZ stappvargen Pass Labs 1 21st February 2003 12:29 PM
Page generated in 0.11886 seconds (64.37% PHP - 35.63% MySQL) with 11 queries
