The Pass Monster?
The Pass Monster?
Old 1st February 2005, 04:07 AM   #271
gearheaddruid is offline gearheaddruid  United States
Default Le Monster.
I am not sure torque would be as much concern as cargo room! Does that Bimmer have a trailer hitch?
I know, get one of those 4kw inverters for the car and you can run the car stereo through the monster!!!!
Finding new ways for the extreme mis-application of high tech!
Old 1st February 2005, 06:25 AM   #272
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by Coulomb
I found some nice 7500 uF 450 VDC caps recently, was not sure if I should pick them up. After all what suicidal maniac would build an amplifier with +/- rails over 400 VDC!!!
Anthony
400V that is it ? the amp im working on here will start at that and go up..
The amp i was wanting to build wanted 1200V a we bit hi to start off...
Old 1st February 2005, 07:22 AM   #273
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by Nelson Pass
I suppose I could always have that mid-life crisis and get the Lola....
Let us hope you are talking about a car !
Who is going to put the thumbscrews on Mr Rollins to hand out the choice of Tubes for the Pass missiles ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 4th February 2005, 04:39 PM   #274
MikeW is offline MikeW  United States
MikeW's Avatar
How is the tube front end design?
MikeW
Old 4th February 2005, 06:42 PM   #275
SmarmyDog is offline SmarmyDog  United States
SmarmyDog's Avatar
Here's a little update on the power supply section for Le Monstre. Some stuff has been re-arranged since the initial PSU schematic posting by Mr. Pass. This was to accommodate the parts on hand. I tried to keep the functional topology unchanged. Please let me know if I've messed anything up.
-Casey Walsh
Old 4th February 2005, 06:44 PM   #276
SmarmyDog's Avatar
Here's a more readable PDF...
Old 4th February 2005, 06:54 PM   #277
Mike must be a relative, he has my shirt collar size and he is the only one who understands me.
Can you stop the Lollypop spinning, it already convinced me i am a mushroom !
Old 4th February 2005, 07:07 PM   #278
lawbadman is offline lawbadman  Jamaica
lawbadman's Avatar
Pardon my ignorance but I was looking at the psu circuit and i dont understand how the BR1-4 are connected. The configuration seems odd. Could someone explain how it works?
BTW when will the amp schematic be done and what will be the power output?
One more thing, I dont see any DC blocking caps on the AC lines, are there any plans for any cuz if the transformers are torodial there will be hum which I am sure you guys know. Or am I just not understanding this PUS.
Keep in mind I am no expert i'm just trying to figure this thing out.
Lawrence
Old 4th February 2005, 07:30 PM   #279
It worked, and he said i am a nut !
Casey, i am your master, give me your amplifiers .
(btw did you think of the possibillities of what you can do what all those selected Mosfets you will not be needing ? )
Old 4th February 2005, 08:11 PM   #280
SmarmyDog's Avatar
lawbadman: My house has it's own power transformer and I don't think I have any 1/2-wave rectified loads around, so hopefully the trafos won’t hum. If they do, I suppose I could add a couple 470,000uF low-voltage electrolytics back-to-back with protection diodes. That will only introduce about a 2V sag under full load.
Jacco: But you are a nut! Regarding the leftover thousands of transistors, I thought the "Kilowatt Brothers" would use them for mass production of these babies. (Just kidding Mr. Pass).
-Casey Walsh
The Pass Monster?Hide this!Advertise here!
Pass Monster????? kilowattski Pass Labs 29 31st July 2005 05:01 AM
