What will be the best way to implement a volume control for the XBoSoZ , using the PGA2310 (controled by a PIC)? For the XBoSoZ you need 4 pots in total - with 10k values.
Any suggestions welcome, keeping in mind that I just discovered PIC's and starting to learn them PGA2310: http://focus.ti.com/docs/prod/folder...t/pga2310.html XBoSoZ: (as designed by Henrik) http://www.diyaudio.com/forums/attac...p?postid=67322
"Be carefull who's advice you buy, but be patient with those who supply it." From Baz Luhrmann's - Everybody’s Free (To Wear Sunscreen) |
#2 |
97 views and nobody can give me the slightest clue
![]() Will it work if I for example set the pots at 80% and then control the line-in with the PGA, then I only need to control 2 levels ?
#3 |
Hi Jdev,
Be patient not a lot of folks have experience with this type of attuenator. I too have an interest in checking them out, and planned to experiment with a pair of these devices in the near future. There is probably a good reason why the highend audio vendors have not used these one chip attuenators. Placing op amps in the signal path of a circuit that strived for minimal devices in the signal path is contrary to the design intent. Most folks have a high quality pot or a high quality resister network selected by relays or a rotary switch. There is probably not a lot of folks in the forum who have taken this approach. However I'm sure someone has and they will probably answer if they see the post. Good luck, -David |
#4 |
Banned
ok,
i have some experience with those chip attenuators: http://home.tu-clausthal.de/~tpa/PGA/index.html as well as with BZLS http://home.tu-clausthal.de/~tpa/relais/index.html for which i use a relay attenuator. Guess why. IMHO if you want to build a volume control for a chipamp or a AD797 or OPA627 preamp, the PGA2310 / 2311 are fine. The minimalists circuit of BZLS calls for good quality potentiometers, switched attenuator, or relay volume control. |
#5 | |
#6 |
Will the PGA sound worse then cheap pot's? My XBoSoZ was constructed with all general purpose components, nothing special. I also want to do the PGA thing to learn more about PIC programming, just want to be sure IF I connect it to line-amp, that I don't cause problems.
#7 | |
Banned
I would use the PGA instead of the BZLS, or in front of it in case you must. Better instead, you need no additional gainstage if using PGA. |
| WTB programmed control chip for pga2310 | jaudio | Swap Meet | 2 | 29th August 2006 10:27 PM |
| 5.1 Volume control with PGA2310 | abid_rehan | Chip Amps | 30 | 8th September 2004 12:55 AM |
| Control of PGA2310 | nowater | Digital Source | 1 | 22nd January 2004 02:43 AM |
| PGA2310 Digital Volume Control | alaskanaudio | Solid State | 96 | 24th November 2001 12:51 AM |
| Page generated in 0.09419 seconds (75.62% PHP - 24.38% MySQL) with 10 queries |
