help,
I setup my x- bosoz for the first time 2 days ago and I had a little buzzing and some nice hum. On checking my wiring both channels of my dual mono psu went to ~4v under load. The psu units checks out fine under no load but under load the output voltage goes close to zero. Using what I have (a fluke rms volt meter) and the built in diode checker the zeners on the source of the output mosfets seem to be shot. (z115 and z116 in the circuit) So does anyone know what could make those go, if this is truly my problem? Thanks for any help of suggestions. It's amazing how Nelson strives to make these circuits as simple as possible and I still need to write on the "Purple Pages" for help. -dave |
#2 |
What is the difference between having a 9.1v zener from regulated V supply to the mosfet gate, as in the bosoz.
Vs, in the p1.7 there is a 50v 1a diode 1n4001 from gate to unregulated. I have a bosoz with a c-r-c that has slighty more capacitance than the p1.7. Would I be better using ther didoe protection circuit used in the p1.7 due to the added capacitance or does it matter. -dave |
| Please Help!!! Decoupling Zeners | arupg | Solid State | 22 | 31st August 2007 07:16 PM |
| Should I use high voltage value zeners or multiple lower voltage zeners in series? | jarthel | Parts | 7 | 30th May 2006 04:56 PM |
| Zeners As Rectifiers | mrfeedback | Solid State | 5 | 28th November 2002 03:33 AM |
| Zeners For Input Question | vdi_nenna | Pass Labs | 4 | 1st April 2001 07:30 PM |
| Page generated in 0.05981 seconds (68.42% PHP - 31.58% MySQL) with 10 queries |
