Hi averybody.
I have controlled the output of my ZenV4 with a scope, and I discovered that there is an oscillation at about 300KHz with 25mv amplitude. Is this normal, or could it be a problem? The only differences respect to the original schematic, is the feedback loop resistor modded in 470K and input resestor in 34K for a gain of about 22dB. Feedback capacitor is 4.7p silver mica. Thank you.
Michele |
#2 |
The one and only
This is not normal. You will probably want to consider
the values of C3 and C12, both frequency compensation caps. Also you did not mention what load it might have been connected to. |
#3 |
How about LW transmitters near to your facility?
#4 |
C12=4.7p
C3=1n Load 8 hom No LW emitter (I am in a bunker 7 foot underground. Amplitude is 10mV on one channel and 25mV on the other. Any suggestion? Thanks. Ciao.
Michele |
#5 |
Banned
Did you measure only at the output or did you test if its the regulator thats oscillating?
#6 |
I havn't measured the regulator, but I have seen that no oscillation occurs until signal RCA arn't attached.
Ciao.
Michele |
#7 |
Is the input signal clean? (must be measured at the input of an amplifier, not the generator alone).
#8 |
Hi PMA.
I don't know. The generator is a CDP transformer coupled. This evening i'll try to measure the source signal. Thank you for now. Ciao.
Michele |
#9 |
OK. In case you find no oscillations in the input it is Nelson to answer. I do not know how the Aol vs. FB Bode plot of this amp looks like.
#10 |
The one and only
Try increasing C3.
Also look at ground with your probe and make sure you don't see the oscillation there. |
| Getting rid of oscillations in the preamp | engels | Tubes / Valves | 11 | 10th June 2007 09:23 PM |
| ZenV4 oscillations problem | fastcross | Pass Labs | 1 | 28th August 2005 09:56 AM |
| How to test for oscillations? | Jye | Chip Amps | 13 | 20th October 2004 11:56 PM |
| Oscillations in P3A ?? | Stormo | Solid State | 3 | 20th January 2003 09:34 PM |
| Aleph 3 oscillations | Koy | Pass Labs | 4 | 22nd April 2002 04:56 PM |
| Page generated in 0.09969 seconds (74.08% PHP - 25.92% MySQL) with 11 queries |
