Europeans.....
Where have you found the 2*60V trafo's for the BOSOZ?? Cheers Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#2 |
Banned
i use 2 2*30V trafos
#3 |
I thought of doing so as well, but I'm running out of space so I'd like to have a single trafo for each channel.
I am aware of the fact that I just might be asking for something that hardly exist, and in particular not off the shelf. Magura
#4 |
Banned
http://www.mueller-rondo.com/start.html
2*60V but smallest in standard range is 300VA. custom made http://www.trafobaule.com/Wunschtrafo/wunschtrafo.html |
#5 | |
Hmm, looks interesting! Have you got any experience with them?? Magura
#6 |
Banned
no, i extracted these vendor adresses from some german diy electronics fora.
#7 |
You can also get any voltage done custom (min. 2 pieces) at Schuro at extra cost of 6 Euro per piece.
http://www.schuro.de/preisl-v-rkt-ms-sw.htm Another alternative -- no extra charge : http://www.multipcb.de/ger/sites/ind...ukt_02_01.html Or from Airlink (see AX UK group buy) in England. Out of the three, I have only used Schuro before. They do now and then have noise problems with Class A. Patrick |
#8 |
You could also check out:
www.rs-components.se (http://www.rsonline.se/cgi-bin/bv/br...id=-1171329271) for toroids with 2x55V which will work fine. Or: http://www.elfa.se/dk/ They have toroids of brand Toroid, for instance product nr. 56-126-84. This is a 2x50V 300VA toroid. /Niclas |
#9 |
I used 2 trafos 2x30V 50VA each. To save space I placed one on top of the other with a longer screw. |
#10 |
You can use 2 x 55 volts trafos. I have bought mine from RS Components. They are made by Nuvotem Talema. Even better look for their encapsulated versions. If you look in a recent thread I published you can see the trafos in my bosoz. The encapsulated oned were used in my Aksa amp that you may see in the same thread.
Regards George |
| Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? | rhythmdiy | Chip Amps | 9 | 23rd October 2007 12:30 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| Fountek Ribbons Group Buy (Europe, but maybe not only Europe?) | Carondimonio | Group Buys | 34 | 24th October 2004 08:10 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Page generated in 0.12439 seconds (71.71% PHP - 28.29% MySQL) with 11 queries |
