does any one has any ideal how can i add two power meter or power indicator to my sa-4e?build by nelson pass?i like the one that sa-1 has or mcintosh has it has blue light on it and where can i buy the meter
#2 |
#3 |
I can't read GErman and am building an Aleph 1.2 which I want to put meters onto. Which of those boards do I want?
Thanks |
#4 | |
Please note that this are not TRUE WATT meters. They measure only output voltage and display power dependent on a assumed 4 or 8 Ohm speaker load (there is a jumper on the display board to select the 4 or 8 Ohm load impedance). A TRUE WATT meter design would require to measure the actual current flowing into the speaker as well (not only the actual voltage at the speaker terminals) and an electronic circuit that calculates true power by multiplication of voltage and current (P= U x I). For a related discussion please see also here: Wattmeter
Christoph STEAL the BEST - INVENT the REST |
#5 |
So, can this be made on a simple PCB? I'm sure it has been done before correct?
Also, Nelson Pass had a meter on his Stasis amps that sent to 12 o'clock when the power was on, then moved ever so slightly to the right I believe as it's class A gain devices increased the flow of current to the speakers. In other words as the volume was turned up. Is this simply a watt meter that reads a steady milli-amp at power on, then a slight increase as it's max wattage of output is realized? Thanks. I will check the link you mentioned now. C |
#6 |
hi can any one has the way to tell the webside http://www.thel-audioworld.de/module/Vu/vu.htmto provide english becouse i can't read it also i like the VU-128 if any one could get a pair for me that will be a great help i will pay in pay pal in my acounut in ebay |
| car RPM meter 2 | ido2 | Everything Else | 2 | 11th September 2007 09:36 AM |
| how to make this esr meter work with 250uA Panel meter | dytln_02 | Everything Else | 2 | 27th January 2007 11:13 PM |
| inductance meter from a cheap meter? | jarthel | Parts | 3 | 22nd September 2006 06:37 AM |
| Making a milliAmp meter, become a Volt meter | redrabbit | Power Supplies | 11 | 26th May 2006 08:51 PM |
| t-amp vu meter and volt meter question.... | rectaacies | Class D | 7 | 3rd February 2006 12:22 PM |
| Page generated in 0.10208 seconds (74.61% PHP - 25.39% MySQL) with 10 queries |
