Bosoz - AKSA problem
Old 2nd October 2004, 07:57 AM   #1
gchrist is offline gchrist
Default Bosoz - AKSA problem
Today I finished my Bosoz.
I connected my preamp to a small midi system with an input to see if everythink was ok. I gave the preamp some music and I heard music from the midi system. Without a music signal I could not hear any buzz or other noise.
I then connected my Bosoz to my AKSA 55W power amp. I immediatly hear a strong buzz and I smelt something wrong in my power amp. I closed everything down and played the power amp direclty from my cd player. Everythin was ok. The only problem I noticed is that now I can hear a power on and power off screech noise from the power amp for some milliseconds. Previously it was silent.
So the question is: Why is my Bosoz not cooperating with my AKSA preamp?
What may be the problem?
How can I measure my preamps output DC voltage with a DVM?
What may have been damaged in my power amp?
I have measured my Bosoz based on the original article and I got all the measurements correct.
Old 3rd October 2004, 01:29 AM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Most likely culprit is the output of the amplifier bleeding back
to the input of the preamp, and forming a feedback loop that
oscillates, usually up around 100 KHz. This would tend to make
the resistor in the amp's output RC network toast up a bit, but
is probably OK. Look for an ungrounded cable connection or
shield. If you don't use shielded interconnects, consider them.
Old 4th October 2004, 05:01 AM   #3
Mr. Pass,
Thank you for your swift reply. I think that I may have traced the problem to a grounding error in my power amp. I will try to solve this problem and once solved I hope that my Bosoz will be displayed on your diy site also.
Best regards
Old 5th October 2004, 05:08 AM   #4
Thumbs up Problem solved
I have solved this problem. In my power amp I had shorted the heatsink of a rectifier diode to the bottom of the chassis. Everything fixed now and working fine.
I will post some pictures today on a different post.
Thank you
Bosoz - AKSA problemHide this!Advertise here!
BOSOZ Hum Problem hifileslie Pass Labs 12 18th September 2007 04:28 PM
Bosoz psu problem vit Pass Labs 10 21st August 2005 10:10 PM
more bosoz problem. when will it end! cowanrg Pass Labs 16 20th July 2005 05:51 AM
AKSA GK1M versus BOSOZ gchrist Pass Labs 6 19th February 2004 05:16 PM
Bosoz PSU problem CH2 Pass Labs 3 28th June 2003 04:08 PM
