Need an alternative sugestion for replacing the following caps in pic labeled 47 20v (one channel had been replaced with 100 10v on 15v circuit. Also would like to change those brown Mica caps in the RIAA eq circuit. The Mica Caps are 100pf, also have a couple .0033uf anf .015 uf mylar in phon0 path. Styrene should be a better replacement for the RIAA circuit.
Have a couple of unidentified brown Mica caps labeled 20+/- 3% ADI and +1.5N05. This is in the Threshold SL10 going on 25yrs old. This preamp had the FET upgrade. The phono section has some degraded freq response http://munsonandbryan.com/Ebay/SL10004.jpg (larger pic) |
#2 |
The one and only
#3 |
That top electrolytic looks like its leaking, or rusting, or something.
#4 |
I believe the FET upgrade took this preamp to a FET 1 preamp using the 2N5566 FET. Would you have that schematic available?
I tested the cap ESR which appeared to be leaking but it tested good. I will end up changing these anyway due to age. |
| threshold sl10 | intense-tavda | Pass Labs | 110 | 2nd July 2011 09:10 PM |
| threshold sl10 | donadi.tv | Pass Labs | 1 | 15th February 2008 04:25 PM |
| Threshold SL10 modified | SL10User | Pass Labs | 10 | 28th September 2007 09:24 AM |
| Threshold sl10 fs | intense-tavda | Swap Meet | 3 | 23rd December 2006 11:22 AM |
| Page generated in 0.07154 seconds (68.07% PHP - 31.93% MySQL) with 11 queries |
