I´ve almost finished the metalwork for my combined Perpetual Technologies P1-A / P3-A with X-BOSOZ output. Since I will build the output stage using a X-BOSOZ with current source (like in Henriks shematic) I´m not shure if it is really neccessary to use a regulated supply. As far as I can see the bias is set by the current source and won´t change if the dc voltage goes up or down a bit (by changes in the 230VAC line voltage). It will make the supply a bit simpler without the fets and zeners. With the tranny I´m using I will get around +45, -28 volts DC with a C-R-C-R-C setup. I know this will waste a bit of power in the current source but it is a nice transformer (shielded and everything). Does anybody see a problem with the usage of an unregulated (C-R-C-R-C) power supply instead of the regulated one? William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#2 |
I tried it without the stack o' zeners + source follower, but always had some residual crud in the background. Things got much quieter when I used the voltage stabilizer.
(edit: I should add that my raw supply consisted of a set of HEXFREDS for the bridges, a 1.5H (56-ohm ESR) choke from Hammond, and a 10,000 uF ELNA Cerafine cap. I'd have thought that would have been good enough. Then again, I was running an unbalanced output. Maybe that would have turned the tide?) YMMV, of course. You could also leave a bit of room inside to add a regulator board next to your output circuit if it isn't as quiet as you'd like.
Would a woodchuck bother to chuck MDF? |
| X-Bosoz & Power supply pcb's | Kari | Swap Meet | 0 | 1st September 2005 02:37 PM |
| bosoz power supply cap question | Raoul | Pass Labs | 2 | 26th February 2004 04:59 PM |
| BoSoZ Power Supply | 2Bak | Pass Labs | 2 | 23rd June 2002 03:48 PM |
| BOSOZ power supply | audionut | Pass Labs | 2 | 6th June 2002 04:33 PM |
| Can I use the power supply from a BOSOZ | Yochim | Pass Labs | 1 | 9th May 2002 06:29 PM |
| Page generated in 0.07340 seconds (68.84% PHP - 31.16% MySQL) with 10 queries |
