thought that i'd show my pcb layout of AX. It is based on the schematics i found on KK's webpage. Please comment if you see something totally wrong. Any help would be greatly appreciated. Thx, Kari |
#2 |
I'm certainly not an expert in PCB's but it looks like you reserved no space for the diffpair heatsink. They can live without but DC will be more stable if you connect them thermally.
/Hugo |
#3 |
I have now updated the layout. Thx Netlist. Anyone else have any comments?
Thx, Kari |
#4 |
Hello Kari,
Nice symmetrical design. Maybe the powerlines are a little thin. Make them dubblesided with some via's to connect them. Did you have any special reason to use 90 degrees curves? Regards, Johan. |
#5 | |
#6 |
diyAudio Moderator Emeritus
You could add some heat-relief traces to make soldering easy. My Aleph-X board was quite difficult to solder, as I had none.
-- Brian |
#7 |
thanks for the input. No i don't have any special reason for 90 degree angels on the tracks. Does it matter? BrianGT: As i am using Eagle for this i assume u mean "thermals" on the pads? I also got the quote from my pcb fab. 4 pcs with redsolder mask is 100USD (I will order this). However if anyone is interested i can get 10pcs for 120USD and 20 pcs for 190USD. I'll post a new picture of the pcb as soon as i'm done with the modifications. Thx again, Kari |
#8 | |
-- Brian |
#9 |
Dont use 90 degree angles. It is not good, the width of the trace changes and so does the impedance. Round curve is the best one, but 45 degree angle will do nicely.
Regards Anvil |
#10 |
you should add some space between the diff-pair to spend a little heatsink to the fets and perhaps some more space to the componrents around (depends on the dimensions of the heatsink). Would be interested in some boards, too. Bye |
| My new Aleph layout. Comments? | louischia | Pass Labs | 12 | 18th May 2003 08:02 PM |
| Page generated in 0.12402 seconds (70.48% PHP - 29.52% MySQL) with 11 queries |
