I found some transformers I want to use for some pre-amps. They will put out 82 volts unloaded and 78 volts into a 150 watt lightbulb. Will they be big enough for a BOZ pre-amp? They are the same size as some 300VA transformers.
MikeW |
#2 |
If you go to the PassDIY website and look at the Bride of Zen .pdf file you will see that it calls for an Avel Lindberg D4007. If you go to their website you will find it is only 30VA with two 30v secondaries. I think the voltage of the transformer may be a little high but useable for the BOZ. You will just have to make R1 in the power supply a 1 Watt resistor.
----------------------------------------------- Kilowattski |
#3 |
Are those voltages the total or measured from the center tap?
Some combination of caps, inductors, resistors, and/or regulators ought to get you where you want to be. The preamp doesn't really need all that much juice. Jeez, I wish I had access to stuff like that. About all you can find around here are parts for Chevys and Fords. I'm going to have to devote a brain cell or two to how to use an ignition coil for audio use. Grey |
#4 |
Those are rectified DC with 11000uf of caps.
MikeW |
#5 |
I'd say they are plenty big enough. Are you using 100WVDC (or bigger) electrolytics?
If you make the load resistor a little bigger so that the drain sits at 30V, I'd predict you'll get pretty much the same results as in the article.
Would a woodchuck bother to chuck MDF? |
#6 |
300VA is overkill, other then that, it will do fine. With 82 volts dc you might want to adjust the resistor feeding the stack of zeners if you want to get exactly the volts specified in the article.
Sven Sødem |
#7 |
Gentlemen,
If you read the BOZ article, Nelson states that he gets 86 volts DC out of the rectifier across the filter cap. Mike W's transformer will be perfect without modifying a thing.
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 08:36 PM |
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 05:05 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 10:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.09247 seconds (74.76% PHP - 25.24% MySQL) with 10 queries |
