Old 16th September 2004, 10:42 PM   #1
Stabist is offline Stabist  Slovenia
Stabist's Avatar
Default Ground loop ain't always the guilty one
Hi!
My Zen v4 had a little hum - I've tried different ground connections - but is stayed and stayed ... So I just tried to ignore it ...
But I'm quite known beeing annoyed 'cause of little detailes ...
So I've decided to locate the reason - I've noticed that the trannie has "it's moments" - when it produce hum - and bingo - at the same time the hum in speakers increased ...
First thouht was - it's only 360VA trannie - maybe I should implement bigger one ...
But since trannies don't lay around for small bucks - that was not the option to start with ...
Then I've decided to find a logical explanation - and voila - I've found it
The thing is - the trannie is mounted on "fake"/internal bottom plate - the bottom consists of 2 plates - with 8mm space betwwen them ... And both of plates are pretty thin (2 and 3mm) - I guess a perfect way to produce a resonance - so today I've damped the first plate with Dynamat - and VOILA!!! It's almost quiet now To damp the one with trannie - I'll have to dissamble the amp - so I'll need a bit more time to do it - but I'm almost convinced it will become dead silent then
Old 16th September 2004, 11:01 PM   #2
Magura is offline Magura  Denmark
Magura's Avatar
Funny you mention it, I've had similar experiences with inductors for the PSU. If not potted and mounted proper, they can sing along as well, with pretty much the same problems as the result.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
ground loop Jamh Chip Amps 10 2nd November 2007 07:18 PM
Fix a ground loop! sorenj07 Digital Source 2 1st October 2007 06:39 AM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Ground loop hum jag Pass Labs 20 25th November 2002 05:32 PM
Page generated in 0.06863 seconds (72.20% PHP - 27.80% MySQL) with 10 queries
