Okay, probably a dumb question...
In my ongoing Aleph5 project I am disliking the 0.047 uF (or 47 nF) capacitor. Its too big for the KK pcb (where it is numbered C1, I think its C7 on the original layout of mr Pass). As you can see here the leads are almost touching the resistors. I now have 47 nF 630 V MKP from Digikey (leads are 20 mm apart). Is it alright to replace them with 250 V MKPs (eg these Wima 's have leads 10 mm apart ). The holes on the PCB are 6 mm apart. What's best to use here soundwise (and fitting)?? Thanx Ronald
Is that all there is? |
#2 |
Ronald
C7 is there to prevent oscillation IIRC. No problem for the Wima's, C7 is not in the signal path. If any, the influence on the sound will be extremely small. /Hugo |
#3 |
Thank you.
So I could also use MKT instead?? (its a bit hard to find a shop with these small value MKPs and to order them for Gemany is a bit cumbersome, Schuro doesn't alway reply to foreign emails)
#4 |
Sure.
/Hugo |
#5 |
Remo has Chateauroux MKP 0.047 for 1,40 euro.
Kost een drol |
#6 | |
You mean "Kost geen drol" ? |
#7 |
Whatever... I don't give a ****
(Apology for my language |
#8 | |
Dimensions are 10*16. Standing on a flat side it might fit.. Although its probably too good for this purpose. Unfortunaltely going over does cost more than a drol. I'll ask him to mail it. edit. damn verzendkosten 10 euro...
#9 |
I'm using one standing straight up. No problem there. It takes almost no space.
Maybe it is time to just start your car. (I'ts a 20 minute drive from your place?)
#10 |
bend the wires like this an there no problem at all, I used the exact same cap
Ralph |
| Pot for my Aleph5 | Llafriel | Pass Labs | 2 | 29th August 2005 10:15 PM |
| Another Aleph5 | mefinnis | Pass Labs | 57 | 2nd June 2005 01:10 PM |
| Yep, another Aleph5 | rwagter | Pass Labs | 19 | 31st May 2003 08:06 PM |
| HELP .... Aleph5 | mefinnis | Pass Labs | 17 | 10th March 2003 05:32 AM |
| my aleph5 ... | sernikus | Pass Labs | 13 | 21st June 2002 10:15 AM |
| Page generated in 0.08913 seconds (80.73% PHP - 19.27% MySQL) with 11 queries |
