Old 11th September 2004, 05:19 PM   #1
Dr. ODD is offline Dr. ODD  Germany
Default thermostatic Switch
Hello
I have a Question about the thermostatic Switch in Aleph Amps
Is it a "you canot kill this Amp even if you take it to the Dessert and listen to your music whith 60 degree outside tempratur" decision, or is it " I dont want you to burn down your House if something fails" decision ??
In other words, is it save to leave it out or is it nessesary to have it ???? And what cold be the failiure where I need it ???
Old 11th September 2004, 06:04 PM   #2
The one and only
Nelson Pass's Avatar
The answer is both.
With the proper fuse value, it should not be possible to
ignite something like cheesecloth (the standard material)
under any failure mode in a properly designed product.
This of course presumes that the consumer has not put a
20 amp fuse in the product.
At the same time, we have been able to confirm that amplifiers
do not tend to blow up when sinks reach 75 deg C., which is
the value we specify.
We do commonly encounter consumers who run the product in
a closed box or on top of another one or more of our amplifiers.
Old 12th September 2004, 08:06 AM   #3
Thank you
Old 14th April 2007, 01:48 AM   #4
Default Thermostatic Switch@75C
I try to find Thermostatic Switch@75C part number in google.but can not find anything.Any body provide this part detail part number or manufacturer?very thanks.
Old 14th April 2007, 02:10 AM   #5
Thermostatic isn't a company, it's just saying that the switch functions like a thermostat. Parts catalogs abound in such things. Use any equivalent part that suits you.
Grey
Old 14th April 2007, 02:19 AM   #6
Very thanks Grey.I found the detail in other thread
questions on aleph 2 parts
Leo
Old 19th April 2007, 02:51 PM   #7
Send a message via ICQ to jgeissin Send a message via AIM to jgeissin Send a message via MSN to jgeissin Send a message via Yahoo to jgeissin
Look in Mouser under 'thermostat'. They are made by Stancor.
Thermal cutouts are hard to find anymore because everyone is reducing parts count, using electronics monitoring of heat or just don't care!
(Page 1624 of catalog 629, search for 'Stancor Snap Action Disc Thermostats').
My wife is acting funny since I told her that I was bi-amping the listening room.
Old 23rd November 2011, 09:26 AM   #8
nar is offline nar
nar's Avatar
Sorry to bump that old thread.
I currently build Aleph_J from my old Aleph_4 chassis and parts.
I use thermostatic switch, but since the amp is in 2 cases, I end up with no possibility to put it on mains ( 230V here ).
I happen to put it on the 24V rectified rails. I chose the CCS side, V+; instead of V-, because I thought it might be risky.
Assuming all the CCS are on V+ on the Aleph design, there is nothing dangerous for the speaker in case the thermostatic switch breaks the V+ rail ?
Thanks for your input.
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright
Old 23rd November 2011, 10:12 AM   #9
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
you'll kill your speakers , sooner or later
break a leg purposely , put longette on , just as precaution for breaking arm .......
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 23rd November 2011, 10:18 AM   #10
nar is offline nar
nar's Avatar
I'm not able to translate Zen Mod language efficiently.
Do you mean I'd better use longer wires from the 230V to feed the thermostatic switch for safe operation ?
Best,
nAr
switch-on, switch-off sequence for preamp/amp cbutterworth Tubes / Valves 1 2nd March 2007 12:41 PM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
Switch DJ Exprice Chip Amps 11 29th June 2006 01:41 PM
Main on/off switch for amp using a piezo switch using_e Solid State 13 20th June 2006 05:55 PM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
Page generated in 0.11044 seconds (81.30% PHP - 18.70% MySQL) with 10 queries
