#11 |
dunno what you are going to use - longer wires for 220 ( I'll not do that ) or stand by circ ( with relay for 220Vac and small xformer , then relay coil through thermal switch) ....... but using TS contacts for routing several A of DC is big nono , at least in my book
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#12 |
use the temp switch to activate a protection scheme.
That protection scheme could have a variety of inputs. Some of the triggers may operate better if they latch ON on trigger and require a mains power OFF to reset.
regards Andrew T. |
#13 |
I will end up using the switch on mains like in legacy Alephs. Thanks for the input !
Best, nAr
"... Audio needs the thinnest wire ..." Rowan McCombe "Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright |
| switch-on, switch-off sequence for preamp/amp | cbutterworth | Tubes / Valves | 1 | 2nd March 2007 12:41 PM |
| Never try to switch 450V DC at 3A with a conventional mains switch... | Eva | Power Supplies | 28 | 1st November 2006 09:24 AM |
| Switch | DJ Exprice | Chip Amps | 11 | 29th June 2006 01:41 PM |
| Main on/off switch for amp using a piezo switch | using_e | Solid State | 13 | 20th June 2006 05:55 PM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 08:23 PM |
| Page generated in 0.05935 seconds (70.88% PHP - 29.12% MySQL) with 10 queries |
