static noise and hum - Page 2 - diyAudio
Old 19th June 2002, 07:33 PM   #11
chris ma's Avatar
Mr. Pass,
Actually what I really meant to ask was a basic question, because I do not know how to measure a capacitor using a multimeter to check whether it is working or not.
Sorry...
from a guy with O level physics more than 20 years ago!
Chris
Old 19th June 2002, 09:03 PM   #12
The one and only
Nelson Pass's Avatar
The Aleph design is quite stable without bypass
caps, even with some length on the supply lines,
and so I am inclined to presume that your caps
are fine, but that you have another problem.
Those lead lengths do look a bit long, tho.
Old 19th June 2002, 11:12 PM   #13
Thanks,
does power supply lines are that long, for flexibility reasons, this way I can move the heatsinks, turn, flip, lay them on their back etc. When I am going to build them in a case I will remove most of them, and put the shortest path between the powercaps and the boards!
I will shorten them just to see what happens!
Edwin
Old 19th June 2002, 11:15 PM   #14
The noise goes away.
I had a major crash when I shorten a resistor with the 9610's (see other thread). After I recovered from this crash, the channel with the '50hz buzz' in the tweeter, is completely silent now.
The hum in the woofer of the channel has reduced but it is still there for a bit.
Edwin
Old 20th June 2002, 02:42 AM   #15
PassFan is offline PassFan  United States
I know it's a dumb question but, while you are testing this thing do you have anything plugged into the input or have the input shorted to signal ground? If you don't have anything plugged into it or have it the input shorted it will hum. I'm not out to be insulting but I always look for the simple things first as they're the ones that throw the hardest curves.
Old 20th June 2002, 03:32 AM   #16
Originally posted by PassFan
If you ....... ....have it the input shorted it will hum.
Skippy-
I would think that that is the best kind of "no input" if that's what you want. No?
It's important to me since I have some problems of my own, and could benefit from this thread.
I have hum in my pearl phono stage, and when I short an input it is reduced.
Vince Harris
Old 20th June 2002, 04:18 AM   #17
Vince:
That should have read "and not have the input shorted". Thanks for catching that. You should not have an open input when testing, naturally when it is in use something will be plugged in, but when you are testing you must give the circuit a point of reference in order to adjust it, it keeps the noise down as well. Everything I have tried has hummed with an open input. If you have an o-scope it should be easy to find. Start looking back towards the power supply. Phono stages are high gain and more prone to these problems. I have a problem with a borbely phono stage that I recently built and it turns out it was coming from the turntable. Simply plugging in some shorting plugs showed me that without any tools or meters. You can also use a meter on the output to see if it is dc offset. You should read under .050 millivolts dc. Most stuff will go down to under.010 + or -. If the pearl has a servo circuit it will be around.002 or zero, I hav'nt looked at the pearl very well yet but I am sure it is an excellent preamp. Good Luck and thanks again.
Old 20th June 2002, 07:47 AM   #18
Hello,
it will hum a bit (I should stress the bit part, it is not a 300mV ground loop hum, I know when they hit me ;-) however one channels hums less than the other. So I know it is possible to get the hum down with these wires, power supply etc. When I swap boards or swap powersupply, the hum always stays with the board!
So this why I asked for parts more prone to hum, or parts which suppress hum on the boards, so I could swap a few. I read somewhere that the 220uf C8 does something like this, so I will buy 2 new ones and try them...
The inputs are shorted, or connected to my Pass Aleph P (a real one, not a DIY, which I could buy for a good price second handed) .
Edwin
Static noise in K-16LS Rukahs Tubes / Valves 2 16th June 2009 05:49 PM
Static noise from new system 79corona Car Audio 1 5th September 2007 08:53 PM
B&O Turntable static noise Please help! danioh Analogue Source 2 11th April 2007 07:29 PM
static noise question kambrian Car Audio 2 15th July 2005 11:59 PM
Removing static noise from stereo. Trist Everything Else 2 7th June 2002 05:57 PM
Copyright 1999-2017 diyAudio
