Old 5th September 2004, 12:53 AM   #1
jrsun is offline jrsun  United States
Default CRC or CTC for PSU of Aleph-X
C1 - R - C2
or
C1 - Thermistors - C2
C1, C2: 68mf, 9.4 mohm ESR
R: 2 0.47/5W in parallel
Thermistor: 2 CL-60 in parallel, 10ohm/18mohm
Can thermistors in CTC still provide inrush current protection ?
Thanks!
Old 5th September 2004, 03:41 AM   #2
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
I think Peter Daniel used them in his Aleph-X. Shouldn't be a problem.
I'm not sure about inrush current...
On my Aleph 2's I used the CL-60 part on the AC line - before
the transformer.
(I think there's a schematic on Digikey in the product info of the
CL-60 that shows common useage)
m.
Old 5th September 2004, 04:16 AM   #3
batee is offline batee  United States
batee's Avatar
Only one set of T's between the Caps (CTC): Since C1 is still connected directly to the rectifier, it's still going to cause a huge inrush. Since C1 is usually larger than C2 (higher ripple current, so put more in parallel), the majority of inrush current remains.
I think I remember someone saying that the XA200 that Nelson showed in pics had three sets of thermistors. Here's how I'd guess they're arranged:
One set of four in parallel on the primary side of the transformer, and one set of four on each of the rails (+/-) between C1 and C2.
Got some stuff on order and plan to build this ckt unless someone comes up with a better idea.
Bryan
Old 5th September 2004, 07:47 AM   #4
I remember passlabs stopt using them, because of the thermal runaway when using thermistors in parallel.
Old 5th September 2004, 07:22 PM   #5
Thanks for the responses !
Looks like CRC plus CL-60s at the primary ends is the way to go !
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.09263 seconds (63.32% PHP - 36.68% MySQL) with 10 queries
