Old 3rd September 2004, 07:49 PM   #1
Odysei is offline Odysei  Lithuania
Unhappy Problems with Zen V4
I'm having problems with Zen V4, it isn't working. It's 1.3Amp version. When I turn power on r0 shows 0,68V it lasts about 2secs and then it drops to 0V. When I unload main power capacitors to 2V from 51V and restart the amplifier, it happens the same way everytime. Voltages everywhere else are alright. All Transistors are installed right and works 100% (they're not dead after events), all 0,47ohm resistors are fine, all capacitors loads and unloads 50V current. The amplifier is as cold ice I mean mosfets don't get warmer at all. Right voltages exists from D to S, but I think no current flows through them.
Any advice is welcome.
Old 3rd September 2004, 08:07 PM   #2
pro is offline pro  Italy
pro's Avatar
Try to recheck all the weldings, some one could be 'cold'.
Ciao.
Michele
Old 3rd September 2004, 08:17 PM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default Re: Problems with Zen V4
Originally posted by Odysei
Voltages everywhere else are alright.....
Do you mean ALL voltages are OK everywhere except for the power mosfets?
What voltages do you get at both IRFP's?
/Hugo
Old 3rd September 2004, 08:25 PM   #4
You may be charging a capacitor that ends up shutting off the current source. Check to see that the two 220uF caps are wired correctly.
I finished troubleshooting my new Zen V4 two weeks ago - it works great now. I designed my own boards and it turned out that I missed one copper track.
Good Luck,
Jeremy
Old 4th September 2004, 06:00 PM   #5
q1 voltage 23v, q2 - 21v, as I said all normal. Very strange, I can't think of any solution
Old 5th September 2004, 10:19 AM   #6
Netlist's Avatar
I could be wrong and I can't figure out why it isn't like that but should the source of Q2 not be something like 0.66V positive against the drain of Q1?
/Hugo
GFA-565 problems ben62670 Solid State 5 14th August 2008 06:36 AM
HK AVR 335 Problems utjay2008 Solid State 0 21st October 2007 02:26 AM
Sub Amp Problems Thanks! crippledchicken Solid State 2 10th January 2007 06:17 PM
JLH problems serosmaness Solid State 11 2nd November 2004 06:17 PM
RFI problems laz Solid State 3 21st February 2004 07:06 AM
Page generated in 0.10016 seconds (62.27% PHP - 37.73% MySQL) with 10 queries
