Hi averybody.
I have made last year a Zen V4, and it sounds very good. Now because I connected it on the mid high section of my three way speakers, 700 Hz 12 dB octave crossover, I am planning some modification for the V4. First one, increase the gain so to reduce feedback. The question is: Do is it better to decrease input resistor R2 or increase R3 or both.? I am planning about 20-22 dB of gain. any contraindication for this gain ? Second mod, is to decrease C2 to 0.5u so I have a light hi pass at the low frequency (-3 dB at 50 Hz) for unload the gain fet. Last mod, to change C1 (10mF) with two 1mF (panasonic FC) back to back, with a 221K rersistor from +rail to the mid of the two caps for a bit of bias (should work better with reactive load). Did some one made some things lke this? Any contraindication. Tks to averybody. Ciao.
Michele |
#2 |
The one and only
Probably better to increase input resistor, but try it both ways.
If you want to hi pass filter the amp, do so at with a series capacitor on R2, not the interstage capacitance, which will affect the loop stability, and then check it for stability anyway. C1 will already have a bias, so it doesn't need that arrangement. |
#3 |
Many thanks Mr. Pass.
Ciao.
Michele |
| NHT 3.3 Modifications | SY | Multi-Way | 22 | 22nd June 2008 05:12 AM |
| DAC-in-the-Box modifications. Again. | Aleksunder | Digital Source | 1 | 19th July 2007 03:10 AM |
| DAC modifications | elaar | Parts | 5 | 29th May 2006 01:11 PM |
| Transport Modifications...would these help??? | Spiritzly | Digital Source | 1 | 30th May 2005 01:42 AM |
| Results of Modifications. | pixie | Solid State | 0 | 2nd February 2001 04:31 PM |
| Page generated in 0.08266 seconds (62.37% PHP - 37.63% MySQL) with 10 queries |
