Old 30th August 2004, 09:40 AM   #1
aparatusonitus's Avatar
Default X-HDAM Opamp from newbee
First of all, I have to say I am a complete beginner in electronic design, so please don't laugh on this one. For this circuit I referenced numerios circuit from Nelson, Ken Ishiwata, Borbely, Kaneda, Elektor, etc. etc... and of course you guys. Is it something completely wrong, is it X, how to fix it, and proceed
with biasing?
http://img.photobucket.com/albums/v5...-HDAMOpamp.png
Old 30th August 2004, 06:31 PM   #2
The one and only
Nelson Pass's Avatar
If you want it to be X, I think you need to feed the output
back to the inputs. Feed back .....
Old 30th August 2004, 10:42 PM   #3
Hi Nelson,
It's late here, so below is a quick drawing of feedback network. How to prevent "hall of mirrors" efect, e.g. where to connect "magic resistor" and two others?
Good night and thanks Nelson
http://img.photobucket.com/albums/v5...MOpampRev1.png
Old 31st August 2004, 08:44 AM   #4
Well, I think this one is more in accordance with Nelson's patent...
http://img.photobucket.com/albums/v5...HDAMOpamp1.png
Old 31st August 2004, 12:58 PM   #5
And here is a circuit from moamps (my fellow croatian) , transformed to X-HDAM Opamp Light... I guess
http://img.photobucket.com/albums/v5...OpampLight.png
Old 31st August 2004, 07:28 PM   #6
Default An old definition of Su-Sy?
Quote: "An amplifier comprising a first and a second amplifier element, whose outputs are connected to a load, a difference circuit which comprises a comparator, in which the output signal of the first amplifier element is comparated with the input signal thereof to produce a correction signal which is applied to second amplifier element, and a second substantialy identical difference circuit which comprises a comparator in which the output signal of the second amplifier element is compared with the input signal thereof to produce a correction signal which is applied to the first amplifier element; a desired signal to be amplified being applied to both amplifier elements. The two amplifier elements, which may be preceded by a preamplifiers, take the form of power amplifiers. Because the distortion signals appear at the load as "common mode" signals, the overall distortion becomes substabtially zero in the case of equal attentuation in the two difference circuits. The power amplifiers may be provided with a voltage output as well as a current output."
Maybe, but what about noise?
Old 1st September 2004, 07:29 PM   #7
Default An old circuit of Su-Sy...
...should be like this?
http://img.photobucket.com/albums/v5...yAmplifier.png
HDAM / Diamond Buffers Q RnR Solid State 0 21st April 2009 09:59 PM
Marantz HDAM SA BTomi Digital Source 1 1st December 2008 06:35 AM
hdam and aleph-p tze-hao yen Pass Labs 10 25th May 2007 04:03 PM
HDAM Bypassing poynton Digital Source 13 18th May 2007 08:22 PM
Marantz HDAM module parsecaudio Solid State 7 19th December 2006 02:00 AM
Page generated in 0.11376 seconds (67.26% PHP - 32.74% MySQL) with 10 queries
