Old 30th August 2004, 02:03 AM   #11
Very nice design! Are you putting a top plate on?
Dennis
Old 1st September 2004, 12:03 AM   #12
Dennis,
Probably a clear lexan top. I'm still undecided really so could go either way, but there will be a top. Some day when I ever get enough time to do it......
Mark
Now I too Have a Cool Screen Name!
Old 1st September 2004, 10:23 PM   #13
GeorgeBoles's Avatar
Default Aleph Mini's
Dear High Bias
What constituteth an Aleph-Mini. Is it a lower voltage Aleph 2? Fewer output devices? Does it have balanced inputs?
George.
Old 1st September 2004, 11:02 PM   #14
Default Change of Tack
A search for Aleph Mini answered most of the above questions
leaves more!
Which is the schematic you actually used? I found a series of them, apparently often wrong. All slightly confusing.
Is there an "original" or "final recipe" which you used or referenced?
George.
PS I thought I used to be able to edit my posts. I cannot seem to be able to do that now. What has happened?
GB
Old 1st September 2004, 11:25 PM   #15
Blame the original Mini-A on me.
There's a thread somewhere back about two or three years ago called The Mini-A. It's basically an Aleph 3 cut down to run on 15V rails. My target wattage was 10W. The circuit will take a reasonable amount of variation in the rail voltage, but as you start getting up near 25V rails, you'd be better off looking at Nelson's "real" Aleph 3 instead of mine.
I have a few new things in mind that I'd like to try. If I can get some time (ha ha!) I'll try to cobble together a Ver. 2.0
Grey
Old 2nd September 2004, 12:36 AM   #16
Grey,
I would love to see a version 2! Go to it please...... Although this Mini is really tight hopefully I'll be able to cram in Ver. 2 somewhere.
GeorgeBoles,
This Mini Aleph was built using Mike W's board and drawing. Mike has done an excelleent job with these amps! Its worked just fine since first turn on just before last Xmas. It stays on more than its been off so I can hinestly say that it probably has a couple thousand hours running time on it. Output power with 120 volt AC in if I remember is about 9.8 watts into 8 ohms and 14 watts into 4 but I'd have to double check it to be exactly sure. Contact Mike through his e-mail. He posted in this thread near the beginning.
Mark
Old 2nd September 2004, 02:49 AM   #17
MikeW is offline MikeW  United States
MikeW's Avatar
Default Trigon
I sent the films for the second version to Trigon. He may do a group buy.
There were 12 of the first version and 22 of the second version. I gave all the boards and the five amps I built to different board members. I hope they enjoy them. I expect to get one back, but he hasn't started building his mini yet so it may be next year until it returns.
MikeW
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
BIB mini-build log and a question on finishing [big pictures, 56K be warned] Glowbug Full Range 21 16th January 2008 08:22 AM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Aleph 5 finally completed icceman Pass Labs 17 19th April 2003 04:12 PM
New Aleph 5 (finally )finished PedroPO Pass Labs 84 10th February 2003 06:55 PM
Page generated in 0.19210 seconds (43.98% PHP - 56.02% MySQL) with 11 queries
