Old 19th August 2004, 01:07 PM   #1
jrsun is offline jrsun  United States
Default rca inputs to aleph-x
2 questions:
1. ground xlr "-" or leave it open or no difference ?
2. change 10k input resistor to 1k to raise the gain ?
Thanks!
Old 19th August 2004, 04:26 PM   #2
The one and only
Nelson Pass's Avatar
1) Ground the - input
2) No. That will give you a 1K input impedance and use up
all the gain the amp has.
Old 19th August 2004, 05:14 PM   #3
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Does the - input need to go through any resistance to ground? If so, any recommended value?
Old 19th August 2004, 06:28 PM   #4
Nelson,
Thanks!
How much bias current you would recommend for 12 x 240s per channel configuration if heat dissipation can be resolved ? 6 amps ? or higher ?
Old 19th August 2004, 07:13 PM   #5
The one and only
A short is just fine.
Originally posted by jrsun
Nelson,
Thanks!
Take the supply voltage, subtract 3 volts, double it, and divide
by 8. This would be the minimum total bias for that channel
(1/2 to each side) if the current sources are set at 50%. Of
course you can go higher or lower, but figure that 12X240's
is a max of 600 watts, and that practically means about 200+
watts of output, in other words, an XA200, although an XA200
uses 32 devices per channel, at about 25 watts or so each.
Switching inputs on Aleph 5 Llafriel Pass Labs 3 15th May 2006 08:47 PM
Aleph P's unblanced inputs and volume Gabster Pass Labs 17 5th May 2002 07:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
