I had this thought on my ride home tonight: what would happen if you sent the same signal to both + and - inputs on a balanced X'd amp?
Wouldn't the result at the output be the amplified noise of the amp? Seems like if the supersymetric concept is good at eliminating noise between 2 identical inverted signals, it would be excellent at eliminating the signal if passed 2 identical signals. Does anyone with an o-scope, an X'd amp, and some time to spare want to give it a try? |
#2 |
The one and only
That's how we get our Input Common Mode Rejection (CMMR)
spec. It is in excess of 60 dB down from what the result would be from the same voltage applied differentially. |
| Testing Harmonic Distortion in a enclosure | ocool_15 | Multi-Way | 6 | 6th December 2007 11:25 PM |
| Testing tube for noise | rotation | Tubes / Valves | 4 | 7th November 2007 12:13 PM |
| matlab distortion testing script to play with | mazurek | Multi-Way | 4 | 21st June 2006 11:27 PM |
| Non Linear Distortion testing - Harmonic Distortion | JMB | Multi-Way | 0 | 20th July 2004 02:54 PM |
| Best low-noise low-distortion buffer? | borges | Solid State | 7 | 9th December 2003 12:40 PM |
