O.K., I've acquired all of the parts and I've already stuffed one board. Here's the questions:
1. I kept getting a cold solder joint on one of the .47uf film caps and I hope I didn't burn it-up trying to re-solder it. I checked the cap for shorts and it seems to be fine. Should I light this candle? 2. The heatsinks (per channel) are approx. 1ftx1ftx1.75". I also have two 1/4" thick 10"x10" milled-aluminum cover plates per channel (these are monoblocks.) The cover plates are vented just below and above the pcb. Am I wasting my time or should I think bigger? 3. I bypassed the .1uf cap to ground on the AC side and used an 10amp EMI filter instead; good idea? 4. There's going to be quite a run of internal hookup wire on both my inputs and outputs inside the chassis. Should that wire be grounded. Should I use solid core or stranded?? Thanks guys (or girls) |
#2 |
The one and only
1. Yes.
2. This sounds big enough. 3. Sure, why not? 4. I use stranded, but only for flexibility and to avoid metal fatigue when the wire is flexed. |
| Some Quad els57 questions! - Novice Questions! | Fanuc | Planars & Exotics | 13 | 5th December 2007 09:26 AM |
| PSU for QSC amp questions | rkc7 | Parts | 5 | 10th November 2005 05:18 PM |
| Last questions about this | Madmike2 | Multi-Way | 9 | 13th June 2005 11:12 PM |
| Questions, questions, from newb DIYer | Phatman91624 | Multi-Way | 41 | 3rd August 2002 02:52 AM |
| Page generated in 0.07677 seconds (66.44% PHP - 33.56% MySQL) with 10 queries |
