Old 11th December 2003, 11:23 AM   #781
Henrik is offline Henrik  Denmark
Hi moe29
Glad you like the xsoz.
But if you are driving it with standard bsoz two diffrent things happens.
1) Too much (IMO) x-feedback because of the higher outputimpedance in the standard bsoz.
2) If you have 10 uF at the output of your bsoz, you will be down -3db at 18Hz. You need at least 100uF, then you will be down -3db at 1.5 Hz.
If this is the case you still haven´t got the full potential from the xsoz. I have been there.
Henrik
Old 11th December 2003, 01:57 PM   #782
It's a waste to to build a 20w SOZ or XSOZ. The most you should go for is 12 watts. Beyond that all you get is a lot more heat but all most no increase in volume at your speaker.
Paul
Old 11th December 2003, 03:14 PM   #783
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Henrik,
Thanks for bringing that up again. I will make the modification and
report back. Maybe my initial listening impressions were biased
because it's something i built? Is there a specific capacitor you
are using for that part? Thanks again for all your hard work in
this area!
Paul,
You are right - there is a steep curve of diminishing returns when
you are dealing with the SOZ and output power. It's easy to be
seduced by the power of the watt
Old 11th December 2003, 03:46 PM   #784
Moe29
I am using Black Gate type N at 47uF at 50V, but they need to bracke in for many hours.
But Panasonic FC with an say 1uF coupling cap should be nice too.
And then X it.
I would like to read about your expierience.
Henrik.
Henrik
Old 23rd August 2004, 10:16 PM   #785
Default x-bosoz gain
The gain at the original BSOZ an SOZ was controlled by R115 and R207, now it is by R120, R121, R122, R123, and R212, R213, R214, R215, all resistors in the X-feedbackloop.
I have kept the original gainlevel, and also this gave the best frequency responce.
Henrik:
I know the formula for original bosoz's gain is 20*log(R1+R2/R15). Is the gain for x-bosoz's gain calculated in this way:
gain=20*log[R1+R2/(R120+R121)//(R122+R123)] ?
Thanks,
Thomas
Old 8th January 2008, 02:26 PM   #786
Hi Henrik,
I have built soz and want to upgrade to your version xsoz and xbosoz with CCS 03 which you have posted in this thread page 18.
Here I have one question,My current SOZ work voltage at +-25V,but you post sch show 19V.Do I need change some components value to match at +-25V.
x soz
Leo
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
