why no Aleph 2 DIY w/ bi-wire? why no Aleph 2 DIY w/ bi-wire? - diyAudio
Old 12th August 2004, 01:21 AM   #1
tomchaoda is offline tomchaoda  United States
Default why no Aleph 2 DIY w/ bi-wire?
A simple question: Commerical Aleph 2 is bi-wired. Why no DIY has made it into bi-wire version? (at least I haven't seen one!)
Thomas
Old 12th August 2004, 02:06 AM   #2
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
mine originally were, but i decided against it, because im going to bi-amp instead.
Old 12th August 2004, 09:51 AM   #3
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Thomas,
I suppose you mean it has two pairs of output connectors? This is not really what I would call biwired as they are just connected to each other inside the case and help people who have speakers that can be biwired.
If your speakers donīt have this facility thereīs no need to put two pairs of output connectors on the back of your amp.
William
P.S. some speakers can be tri-wired........
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 12th August 2004, 06:14 PM   #4
cowanrg's Avatar
most speakers can be bi-amped/bi-wired.
using two different cables, one for highs, one for lows, can help out. its benefitial, but if you bi-amp with two amps, you cant really bi-wire.
some speakers are actually quad-ampable
Old 12th August 2004, 09:11 PM   #5
wuffwaff:
Is is like this? (in the photo)
Does this make the sound better, if I have a bi-wired speaker?
Thanks,
Thomas
Old 13th August 2004, 07:05 AM   #6
wuffwaff's Avatar
Hi Thomas,
yes like that, although - is normally connected directly to the caps (if the amp is not bridged)
I donīt think there will be a difference if you connect your (biwired) speaker to four or two outputs.
Biwiring does make a difference although Iīm happy that my speakers donīt offer this facility
william
why no Aleph 2 DIY w/ bi-wire?Hide this!Advertise here!
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
Aleph wire routing question D97GT Pass Labs 2 22nd December 2006 07:32 PM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 02:58 PM
Copyright ©1999-2017 diyAudio
