I just finished my x-bzls, which was my first hi-fi diy project. The next phase is a 5 watt x-soz which I have all parts for except some case material, and also a Jt-DAC no. 3 with balanced outs. I checked every thing that I could with a meter, and it all looked good. I have no other balanced equipment, so I connected an unbalanced source and an unbalanced amp.... I was stunned!
I wanted to wait to post this until my project was complete, but I am so ecstatic that I can't see straight. Given all that I have read about unbalanced operation, I was'nt expecting the dramatic improvement in sound quality. Now I will work dilligently to finish the rest of my system. All of my equipment is low-end consumer. My source is a sony cdp291 and the power amp is a little 20 watt tascam (very gainclone-like). My speakers are Bose bookshelf (PN#?) This pre-amp has +/- 50 volt rails and has 600 ohm power resistors, 20 uf (2x10uf parallel) output caps and 39 k feedback R. R15 is shorted. It also has 10k input and output attenuators. Also, I used KK boards, as my press-n-peel boards had some trace problems. A sincere thanks to NP for sharing this work... I can't believe I made this! Here is a link to some pics. Also Thanks to Henrik for making the Simetrix sim files, as I used them to help my component selection. Any one considering making a bzls, it well worth the effort. pics Thad Howard
Coiler |
#2 |
Neat job mate. The knobs and the case are very good looking too.
Thank God for DIY audio. |
#3 |
That is one cool Preamp. What are those transformers?
If this is your first: Congrats!! Very neat. You can end up with a first class set of equipment. Keep it up, and keep posting!!! Very nice! Steen. |
#4 |
coils,
Very good job on the enclosure, prefect. Regards. Alain. |
#5 |
Very nicely done!
You should submit some pics to the PassDIY gallery. Cheers, Dennis |
#6 |
First, you said?
What rotary switches did you use? Thanks for share your impressive job and congratulations JC |
#7 |
WHooooooooooHoooooooooHooooo
Veeeery nice /Hugo |
#8 |
If you hadn't told us, I'd have said it was your 31st DIY project. Very Nicely done.
#9 |
Great Work!!
#10 | |
So, how DID you do that lettering and artwork on the back? mlloyd |
| My completed BZLS | tomchaoda | Pass Labs | 3 | 4th March 2011 04:24 PM |
| BZLS pre-amp | garfieldcat | Pass Labs | 4 | 4th July 2005 08:38 AM |
| How hot is your BZLS ? | till | Pass Labs | 17 | 12th August 2003 10:34 AM |
| Page generated in 0.12386 seconds (68.88% PHP - 31.12% MySQL) with 11 queries |
