TJ said:It is output and input should be same pin ? as i know D1 xlr = pin1 to ground , pin 2 = pos and pin 3 = neg ! IF we connect to an Aleph 3 via RCA how ?
Assuming that you wish to drive an Aleph 3 single-ended from
a balanced source, usually you would connect pin 1 to ground
and use pin 2 (+) to drive the hot RCA input. I would leave pin 3
open most likely.
- D1 xlr to rca ?
