Aleph-P(roblem)
Aleph-P(roblem)
Old 4th August 2004, 04:14 PM   #1
Pawel is offline Pawel  Poland
Pawel's Avatar
Send a message via MSN to Pawel
Unhappy Aleph-P(roblem)
Hi!
I've recently finished building Aleph-P preamp and I have a little problem with it. When I use unbalanced input the sound is distorted and I can hear hum, when standing very close to the speaker. When I disconnect negative input from the ground everyting seems to be OK. Does any of you had similar problem before? I need some advise, what to do? I've checked all connections and components twice. Voltages are very close to PSpice simulated ones... so everything seems to be OK but it's not
Old 5th August 2004, 11:29 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Aleph-P(roblem)
Normally grounding the negative input is what prevents
this. Is there potential for oscillation due to no Gate resistors
or no series output resistors? Is it on both channels?
Maybe what you think is ground is not a good ground.
Old 6th August 2004, 09:19 AM   #3
Pawel's Avatar
Thank you for your reply Mr. Pass.
Yes, it's grounding problem. Changing ground connections helped a little bit. Sound is no more distorted and there is much less hum. I'll try to apply star ground topology to my board. Maybe this will help to remove hum completely.
Aleph-P(roblem)Hide this!Advertise here!
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 27 11th November 2017 02:13 PM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 03:15 AM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 04:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 12:11 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 08:55 AM
Copyright ©1999-2017 diyAudio
