#2 |
It should work perfectly.
#3 |
That's the topology I used in mine. It worked beautifully. At the same time it allowed me to use lower rail voltages, seemingly without penalty. (Seemingly = didn't measure it, but I couldn't hear any degradation in my room.)
Would a woodchuck bother to chuck MDF? |
#4 |
Hi scrazy
Your circiut have a gain of about x70, that is way too much, and that is because you have shortend the sources. And you have about 30 Volt bias across R5 and R8, not that it matters in this case, but they arn't really needed. But if you want to lover the negatieve rail voltage to say 8v you have to remoove them. In order to get less gain you need some resistance between the sources to get x10 or something like that. The scematic could look like the one I have attached. Best regards Henrik.
Henrik |
#5 |
If you want to reduce noise a bit, consider putting a small to moderate sized electrolytic across the Zener. It's not really necessary, but it's a cheap, easy way to improve the circuit. The cap need not be a serious audiophile-grade part, as the voltage across it is DC.
Grey |
| Aleph-type current source, but source follower this time | tschrama | Pass Labs | 4 | 29th July 2005 12:55 PM |
| BOSOZ source switching with SE relays | Gabrielshorn | Pass Labs | 2 | 5th February 2004 08:07 AM |
| current source... | costiss | Tubes / Valves | 10 | 31st December 2003 12:47 AM |
| Source follower electret mike -> use with current source? | capslock | Solid State | 1 | 28th February 2003 12:54 PM |
| R21? and Current Source AC Current Gain | macka | Pass Labs | 9 | 20th May 2002 08:58 PM |
| Page generated in 0.08211 seconds (76.84% PHP - 23.16% MySQL) with 11 queries |
