Here are my Pics from my Aleph Ono. The PCBs are from PQuadrat (see Thread http://www.diyaudio.com/forums/showthread.php?threadid=10326&highlight=)
The Case is a 19" Case from the German vendor "Fischerelektronik" .
The toroidal power supply is from thel-audio.
Here are some better pics from the main PCBs. The green foil caps are WIMA FKP2, the brown caps are SIMICs. The red ones are WIMA MKS02 foil caps. the big elco caps and big blue foil caps are the same as on the power supply PCB. The small purple elco cap are from sanyo oscon SG.
RE: Alpeh Ono Pic (Sound)
How does it sound? [/B][/QUOTE]
Well i am very satisfied with the sound. My turnable is a rega p3/2000. My preamp a rotel rsp-1066 and poweramp rotel RMB1075. My speakers are B&W 805N + B&W ASW2500 Subwoofer. I have heard Peter Gabriel "So" and Roxy Musik "Flesh and blood" for example. Both are 180g audiophil vinyls. The Rythmics and percussion (especially from the roxy music parts) are exellent. I also like the good separation of different instruments and the soundstage in deepth and wide. I have only a MM-System but i hope i can visit someone in the near future which has a MC-System on his rega turnable. He has also build the Aleph Ono and i have asked him for measurements on pcb-Power-Supply due to ripple measurements. I have also noticed that IMHO the Ono needs some time (nearby 30 minutes) to work 100%. In the beginning when you fresh switched the ono on i think the soundstage is a little less and also the instrumentation separation is slightly less. The difference is not big but i would say noticable.
RE: Alpeh Ono Pics
I have just tried them but i would say it was only marginally with or
without the thermoglue. So you could leave them or not.
Upupa Epops said:Any improvement with thermoglue ?
RE: Ono Pics
No expecpt the error correction on the Power Supply PCB from the Use PQuadrat. He has postet self the corrections. The circuit is very similary to the original-circuit.
roddyama said:Did you have to make any modifications to the boards/circuit? I have a set of boards waiting on my stack.
Hi Rodd,
I build my ONO with the same boards and did make a few changes. It worked fine as is, but I liked it better after I modified the design a bit. Here's a link describing my modifications:
http://diyaudio.com/forums/showthread.php?s=&threadid=27318
Here's a link showing my ONO in final form:
http://diyaudio.com/forums/showthread.php?postid=355197#post355197
And one last tip - I had really good results using a Teflon cap in the 0.01uf spot in the RIAA feedback network. It seemed to make the biggest difference there.
---Gary
---Gary
What is the vendor of the Teflon cap ?
I have used the WIMA FKP02.
Re: RE: Aleph Ono Pics
The caps I'm using are made by CRC. Their website is here:
http://www.crcfilm.com
I'm not sure if they sell small quantities to the DIYer or not - I got mine from another person here on DIYAUDIO who was kind enough to pass a few out to interested parties.
---Gary
---Gary
TheMyxin said:(...) The Case is a 19" Case from the German vendor "Fischerelektronik" .
Do you mean you bought it straight from the factory?
Thanks Gary,GaryB said:
Hi Rodd,
---Gary
I thought that component selection would be an issue on this project. I'm still gathering parts.
The teflons you're using look like the Russian surplus caps being sold on eBay.
roddyama said:The teflons you're using look like the Russian surplus caps being sold on eBay.
Well they may look the same but the size is very different. The Russian teflon caps are 2-3 x bigger than the CRC teflons. The Russian caps look like they're built to handle a nuclear explosion.
It makes it difficult to fit on the ONO board, although not impossible. You just need to get creative and you have to be tolerant of moderately long leads from the capacitor to the circuit board.
I've got a few of these in my parts bin and I think I had them in an early implementation of the ONO. But the rest of the parts and circuit wasn't tweaked yet. Then I went on a bit of a parts swapping frenzy upgrading to TaN resistors and film/foil polystyrene caps and then to the CRC teflon caps. It wasn't done in the most controlled manner but it ended up sounding really good and I never went back to investigate if the russian caps would have sounded euqally good. And now its hooked up to the turntable and I'm not in a hurry to tear it apart again.
---Gary
Re: Re: Aleph Ono Pics
Yes. You can bye the cases directly from the vendor. Here is the URL
(in Englisch)
http://www.fischerelektronik.de/index.php?id=29&L=1
(in Englisch)
- Aleph Ono Pics
