High speed amplifier
Old 4th June 2002, 07:24 AM   #11
reinhard is offline reinhard
Default to Paul B
why?
in Germany theres a speaker called "Manger Schall Wandler", think you have heard of it. This thing is sounding very good with wide bandwidth amps and is sounding very good with Class A amps, maybe it is sounding spectacular with both.
Reinhard
Old 4th June 2002, 09:08 AM   #12
superstition is offline superstition
Account Disabled
Default MSW & SOZ
I'm driving my Manger's (Zerobox 109) with a 15W SOZ in a horizontal bi-amping setup. Low frequencies are handled by a politically incorrect Yamaha power amp...
Manger's bandwith recommendation only means that you should be aware of e.g. tube amps with an upper limit of 50-100kHz. She/He doesn't say that the faster the amp the better it sounds. Manger demoes his speakers with Vincent SP 991 power amps and although I cannot find any technical info I don't think that these are of extraordinary bandwith.
Btw what is the bandwith of a SOZ?
Old 4th June 2002, 01:32 PM   #13
Default msw --soz
Yes, you are right, they demo with Vincent 991, because it is Class A up to 100 Watt and in a more
payable region than any Spectral or Metaxas.
Regards from Germany,
Reinhard
Old 4th June 2002, 02:43 PM   #14
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
For Reinhard and Superstition!
The Vincent 991 specs:
Technische Daten SP-991
Endstufe Mono
Übertragung: 10 Hz - 20 KHz +/- 0,5 dB
Nennleistung Class A 8 Ohm: 100 W
Nennleistung RMS 8 Ohm: 300 W
Eingangsempfindlichkeit: 2 V
Klirrfaktor: < 0,1% (1 kHz 1 W)
Geräuschspannung: > 95 dB
Eingangsimpedanz: 47 kOhm
Netzanschluss: 230 V/50 Hz
Masse: L 430 x H 180 x T 530 mm (x2)
Gewicht: 30 kg
I have a Vincent Hibrid 226 it looks like been made in China...the quality of the solder and the execution of the solder job is very poor...
Jorge
High speed amplifierHide this!Advertise here!
thorens td 180 in ....high speed east electronics Analogue Source 0 7th October 2008 08:29 PM
High speed comparator bigbulb Class D 25 8th July 2008 09:44 PM
high speed CDP fscarpa58 Digital Source 7 11th May 2005 08:32 AM
high speed optocoupler djdamix Class D 5 21st April 2005 02:54 PM
