General ? On Dual Primary Transformers - Double UP?
Old 26th July 2004, 03:58 AM   #1
Super_BQ is offline Super_BQ
Super_BQ's Avatar
Send a message via ICQ to Super_BQ Send a message via Yahoo to Super_BQ
Default General ? On Dual Primary Transformers - Double UP?
This question might be related to 50/60Hz cycle on transformers.
Let's take a toroidal transformer with the following description:
Dual Primary: 115/230VAC
Dual Secondary: 0-18 & 0-18
From a 230VAC mains power source. We would SERIES the primary and to get 0-36 volts on the secondary we would series them also.
My question is, would it be safe to run 230VAC if we PARALLEL the primary so we can get double the voltage output on the secondary? What impact would doing this have? (more noise?)
BQ
Yellow People for a Yellow World
Vote for Super_BQ, the Asian Alternative
Old 26th July 2004, 08:10 AM   #2
jh6you is offline jh6you
Account Disabled
As far as I understand, the transformer will anyhow keep its original maximum power rating. If so, doubling up the voltages as you plan will pull the maximum current rating down to half.
Old 26th July 2004, 08:52 AM   #3
moamps is offline moamps  Croatia
Default Re: General ? On Dual Primary Transformers - Double UP?
No.
Usually, you will destroy transformer.
Milan
Old 26th July 2004, 09:34 AM   #4
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Unless you specifically know otherwise with the transformer in question, the answer is no. The usual effect is destruction of the transformer.
- Dan
Old 26th July 2004, 10:37 AM   #5
Account Disabled
Audiofreak,
Is the destruction happening due to increased current in primary side? Or, is the story more complicated? Thanks.
Old 26th July 2004, 11:20 AM   #6
kilowattski is offline kilowattski  United States
kilowattski's Avatar
I don't understand why the transformer would be destroyed? Maybe someone could explain that to me. The only reason I can think of is that the primary current would be doubled and the primary windings may not be able to handle the extra current.
Kilowattski
Old 26th July 2004, 11:30 AM   #7
You can find some infos here:
http://www.allaboutcircuits.com/vol_2/chpt_9/11.html
Milan
Old 26th July 2004, 11:34 AM   #8
dnsey is offline dnsey  United Kingdom
Depending on how it's wound, the primary winding might not be designed for the resulting voltage gradient, leading to insulation breakdown, shorted turns, and a possible fire hazard.
Old 26th July 2004, 12:08 PM   #9
Account Disabled
Thanks, moamps!!!
Old 26th July 2004, 12:29 PM   #10
Originally posted by jh6you
Thanks, moamps!!!
General ? On Dual Primary Transformers - Double UP?Hide this!Advertise here!
Single or double transformers for dual mono amp? Bernie7 Class D 1 30th December 2008 02:19 PM
dual primary//dual secondary toroid larryg Chip Amps 22 6th September 2006 10:24 PM
Dual primary wiring for Plitron standard toroid sardonx Chip Amps 6 3rd August 2005 06:16 AM
Finding phase of dual primary tranny sbear Pass Labs 4 26th February 2005 08:11 AM
What ratings stay constant in a dual primary 110/220 xfrmr? leadbelly Parts 1 25th March 2004 03:40 PM
