Another bride of zen completed!
Old 22nd July 2004, 08:04 PM   #1
Kermit is offline Kermit  Norway
Kermit's Avatar
Cool Another bride of zen completed!
It has been more or less finished for some time to be honest. It just takes some time to do the last finishing touches. Once sound comes out, the will to finish the last bit on the exterior tends diminish by the joy of listening. But with the rainy summer we have had in Oslo so far, there has been plenty of time to finish the last 5 % one some long overdue projects.
I’m attaching a few pics if anyone care to see.
Sven Sødem
Old 22nd July 2004, 08:09 PM   #2
Kermit's Avatar
On the inside there is a relay volume control based on that discussed in the “constant logarithmic volume control” thread. It’s controlled with BCD that also controls the display. It’s a bit “prototypish” but it works very well.
Sven Sødem
Old 22nd July 2004, 08:10 PM   #3
Kermit's Avatar
Playing along with my aleph 3:
Sven Sødem
Old 22nd July 2004, 08:17 PM   #4
Kermit's Avatar
Backside:
Sven Sødem
Old 22nd July 2004, 08:18 PM   #5
Kermit's Avatar
Last picture. From the making of the front panel. All cutouts made with router. It doesn’t show well on the pictures (poor camera, even poorer photographer), but the knobs are countersunk in the front panel.
Sven Sødem
Old 22nd July 2004, 08:29 PM   #6
Alain Dupont is offline Alain Dupont  France
Alain Dupont's Avatar
Kermit,
You have done a very good work...
What a good idea to use the router as a milling-machine
Now give us some more details...
Best regards.
Alain.
Old 22nd July 2004, 11:51 PM   #7
CheffDeGaar is offline CheffDeGaar  Europe
CheffDeGaar's Avatar
Kermit,
Just... Wooow.
Very nice looking preamp for a lush sound...
And nice idea for the router. What type of "mill head" did you use ? A one made for wood, or a special one ? And what about the rotation speed ? AFAIR, wood routers spin far too fast for milling aluminium, no ?
BTW, very very nice work. Hope you will have some more rain to complete other nice projects
/Cheff - Falling feels like flying, until you hit the ground
Old 23rd July 2004, 12:09 AM   #8
jewilson is offline jewilson  United States
Send a message via AIM to jewilson
Kermit,
Nice job...
How did the router bits hold up. I cut edges on 13mm aluminium but have not had the balls to do this buy had. I assume you had this clamped in your workmate.
Nice work.
Jim W.
Old 23rd July 2004, 01:30 AM   #9
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
You can make a template and use bearing tipped carbide cutters to make the final pass with the router. And it leaves a very nice edge if your template is smooth. I freehanded a cutout in 1/4" aluminum with a 3/8" carbide mortice bit with beautifull results, then used a chamfer bit to relieve the edge. It take big balls and a steady hand, but the lack of grain makes it quite predictable.
Beautiful work by the way.
Old 23rd July 2004, 06:21 AM   #10
Kermit's Avatar
Like Brian says, a template or straightedge and bearing tipped bit is the way to go. Any bit of decent quality works, but the router must have variable speed, as it needs to be set to a slow speed. Use some scrap pieces to find the speed that works best. Use WD-40 or similar as lubricant. Wherever possible I remove most of the cutout with drill and hacksaw. If working with thicker pieces I screw the template to the backside to make sure it stays where it is suppose to. Clamping the workpiece securely is very important, as any slip can make the bit “dig in” to the aluminium and snap off. Don’t ask how I know..
Alain, here are some details about the preamp:
Chassis is 3mm aluminium except for front witch is 6mm. Top and sides painted with etch primer and spray painted with black acrylic auto paint. All parts finished with clear auto top coat. Separate 9 and 12 volts power supply for logic and relays. The heart of the controller is 3 bcd counters. 1 for input selector and 2 for volume control. Display is made up of 2 dual 7-segment displays. The relays and resistor network is arrange like described in this tread http://www.diyaudio.com/forums/showt...198&highlight=
If you want to know more I could try and post schematics, just have to dig them up and perhaps clean them up a bit.
Sven Sødem
Another bride of zen completed!Hide this!Advertise here!
Bride of Zen, Bride of Son of Zen 2Bak Pass Labs 36 2nd January 2017 08:25 PM
Bride of Son of Zen for Mic Pre? blschuler Pass Labs 1 16th October 2002 02:31 AM
bride of son of zen at +-30v hifi Pass Labs 1 12th February 2002 06:52 PM
Bride of Son of Zen vs. A;eph P Peter Daniel Pass Labs 0 25th January 2002 07:45 PM
Copyright ©1999-2017 diyAudio
