help!!
how do i bias a mosfet for say 50K input impedance but still have good high frequency response?? looking to bias a mosfet at 1.5A bias 40v drain with a output transformer on the drain (64:8 Z ratio). BUZ900 mosfet and around 2v bias. is this possible? Thanks!!!! |
#2 |
The one and only
You don't indicate the mode of Mosfet operation, or whether
the input value is a resistor to ground or a resistor in series with the Gate. Assuming the former, you can use a 50K value to DC bias the input and place a couple hundred ohms and a cap in series with the Gate. Driving that Gate, you will see the 50K at low frequencies, but eventually the capacitance of the Gate will become part of the circuit, much the same way that the capacitance of the connecting cable will, but usually at a higher value. If your source impedance is very high, you will see rolloff at audio frequencies, but if you can keep it down around 1K or so it won't be too much of a problem.
#3 |
well.... i just need 50K input impedance...
dunno what is the difference between those two configurations for the input value. to bias I can connect a 50K resistor from drain to gate then another variable resistor from gate to ground??? another question: Can I add a 1.5 ohm resistor on the source to reduce distortion?? also how do I adjust the overall gain?? btw, the mosfet has a 64:8 transformer between drain and power supply as the load. Thinking about adding that P-channel buffer on the front end.... with adjustable CCS to allow some distortion cancellation. hmmm.... what else... thats all for now. |
#4 | |
The one and only
2) Yes 3) Method of 1) and method of 2) 4) Yes, that will get the input impedance right up there. 5) Sure thing. I hope that answers your questions.
#5 |
so...
what is the best way to bias the mosfet.. and what resistors determine the input impedance?? Thanks! |
| Biasing of IR2110 Mosfet Driver | Razor_Edge | Class D | 16 | 20th July 2006 12:09 PM |
| low-biasing or high biasing in Class-AB amps | Workhorse | Solid State | 124 | 18th October 2005 04:45 AM |
| Power MOSFET class AB biasing | ingrast | Solid State | 29 | 4th February 2005 05:45 PM |
| biasing a mosfet? | AudioGeek | Solid State | 2 | 17th July 2004 06:21 AM |
| Page generated in 0.08081 seconds (75.98% PHP - 24.02% MySQL) with 10 queries |
