aleph3's almost complete! - diyAudio
Old 17th July 2004, 05:51 AM   #1
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
Default aleph3's almost complete!
well, for those that care, as promised, it would take about a week to get a second channel built. after two days of working, i am 90% done with the second chassis! im pretty surpirsed. i got half of it done in one night. another couple days working on it, and i can start listening.
picture 1
picture 2
edit:
i had a slight problem with transformer hum on the one amp (partly because it was running so hot and probably overloading the tranny), so i decided to make it a non-issue. if you look at the transformers mounting, i am using 4 pads for each transformer. from the bottom up its: case, 1/4" rubber pad, the felt pad thing they give you, transformer, felt pad, 1/4" rubber pad, top plate. these things are SILENT now.
Old 17th July 2004, 01:52 PM   #2
eLarson is offline eLarson  United States
eLarson's Avatar
Looks pretty cool. Is that acrylic that you are using for capacitor "clamps"? A good-looking solution in any event.
Would a woodchuck bother to chuck MDF?
Old 17th July 2004, 01:58 PM   #3
fcel is offline fcel  United States
When are you going to complete the amp as shown on your avatar? I remember you have a lot of those chassis ready to go. I'm anxious to hear your progress on those. Any reason why you were side tracked to build other stuff first?
Old 17th July 2004, 02:48 PM   #4
Very nice idea those elco mounts
How did you cut the holes in the plexiglass/acrylic/perspex (don't know the proper word)??
Is that all there is?
Old 17th July 2004, 03:49 PM   #5
Sandy H.'s Avatar
Default !!!
Pretty bleepin' cool. I bet the finished amps will look great. Can't wait to see them.
Sandy.
Old 17th July 2004, 03:53 PM   #6
cowanrg's Avatar
fcel:
i have a large explaination on my website, under the aleph3 section. i basically wanted to get my feet wet with something smaller and simpler first.
after these are done, those amps are next.
Duck-Twacy:
its actually a little difficult to deal with, moreso than i thought it would be. i used a hole-saw. its a bi-metal, used for wood, plastics, and softer metals.
its very slow work, because it can get stuck really easy. i have a big 12" drill press, and it still was pretty tricky. but, after it was cut, i used a sanding drum, sanded the inside edges of the holes, removed the plastic, and its done! it does look awesome in person too. unfortunately, the cap bank covers most of it up. but i still know its there.
Old 18th July 2004, 04:56 AM   #7
your website is not working correctly. i dont get the images on the left
Old 18th July 2004, 05:15 AM   #8
Brian Donaldson's Avatar
I forgot where i read or was told, but use kerosene as a cutting fluid and you'll get a beautifull and smooth cut, but beware. it's flamible. I wouldn't use with a brush motor tool, only inductance motor to avoid sparks. It's not explosive flamible like gasoline or anything, but will burn hot.
oh yey, very nice looking. Sorry if I sent you on goose chases. it wasn't my intent.
Old 18th July 2004, 06:30 AM   #9
cowanrg's Avatar
dieringe,
the images on the left are java. you might need to enable java. however, im planning on changing them, as they slow down the loading time of the site.
brian,
you didnt lead me astray. you helped out just fine i usually use a special cutting fluid for metals, but i didnt know if i should use anything for the plastic, because sometimes oils can melt away or errode plastics. i just wasnt sure. in any event, it worked out fine, but i might not be working with that stuff again anytime soon.
Old 18th July 2004, 06:32 AM   #10
Coulomb is offline Coulomb  England
Coulomb's Avatar
I use dishsoap dilluted when machining Acrylic, like that of my CD Player.
Anthony
aleph3, 30 and 5 kslim Pass Labs 1 9th September 2004 01:58 AM
my little Aleph3 moamps Pass Labs 16 27th August 2003 09:48 PM
Help: Aleph3 PS Upgrade To 50V Jay Pass Labs 2 25th August 2003 04:08 PM
Aleph3 HarryHaller Pass Labs 13 7th February 2002 02:46 AM
Aleph3 PSU victor Pass Labs 3 20th August 2001 11:42 AM
Copyright 1999-2017 diyAudio
