Old 14th July 2004, 08:44 PM   #1
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
Default Choke Coupling
Fellow DIY brains,
I am pondering on a problem regarding two inductors for my Aleph 2 project. I have two 3mH air coils in a CLC supply filter.
I have very little space available, and I want to place both inductors such, that their fields are in line. I suggest that there will be some transformer action, but could I use this to my benefit? Or is this a no-go at all cases?
Bouke
More Power Igor! More Power!
Old 15th July 2004, 12:48 AM   #2
The one and only
Nelson Pass's Avatar
Yes, this works. To confirm that the wiring polarity of the
two coils is the way you want it, measure the AC ripple voltage
of the supply, and then reverse the leads of one of the coils.
If the AC ripple is lower, then there you are.
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Swinging choke vs std. choke in PS Curly Woods Tubes / Valves 2 5th March 2007 08:30 PM
Swinging Choke or Smoothing Choke danFrank Tubes / Valves 4 11th February 2007 11:05 AM
Coupling caps size with grid choke? DHT112A Tubes / Valves 4 7th December 2006 05:22 PM
Output coupling - Choke-coil method? danielle Tubes / Valves 3 15th February 2006 09:57 PM
Page generated in 0.06353 seconds (67.51% PHP - 32.49% MySQL) with 10 queries
