Old 14th July 2004, 02:38 PM   #1
Stabist is offline Stabist  Slovenia
Stabist's Avatar
Default 160VA 2x18V transformer enough for mono A3?
Hello!
I've got 2 superbly build transformers - 160VA/2x18V each - the thing is - they are build to operate "24h/day" supplying those 160VA - so I guess they won't have problems with A3's 100W draws for one channel?!?
Or am I wrong?
'Cause I've noticed that some people use 300VA transformers per channel etc for A3 ....
Oh btw - I'be got 4pcs of second hand Sprague 24.000uF/30V caps - so 2 per channel - will that be enough or should I get another 4 caps (eg new Panasonics 22.000/35V) ...?
Old 14th July 2004, 03:15 PM   #2
MikeW is offline MikeW  United States
MikeW's Avatar
Default OK
They should be OK. You want more caps. Build a C-R-C or a C-L-C it will be quieter and have a little more bass.
MikeW
Old 14th July 2004, 03:34 PM   #3
Stabist's Avatar
Hehe - so the C-L-C or C-R-C is the way to things
Old 14th July 2004, 03:44 PM   #4
I think you should give them a try. Just note
that the voltage will probably be lower than
the A3's +/-25V (no big deal).
I second Mike's suggestion on more caps and
pi-filtering. Less voltage loss with CLC but
then it's probably harder getting the inductors. Of
course, you may want to try it with just 2
caps and see if the noise level is acceptable.
Have fun,
Dennis
Old 14th July 2004, 07:05 PM   #5
Stabist's Avatar
How do I choose proper inductor? Because I've found a "local" shop whit quite a lot of inductors in their offer - and also prices are very aceptable ... I'll just have to check if they have the right value for me ...
Hmm - another project I intend to do - A5 - I have allready 4x25V/900VA transformer and 4 Sprague 69.000uF/50V - 2 per channel ... I didn't intend to use CRC or CLC PSU configuration in PSU - but now I'm not sure anymore - you all talk about hum - and that the way to avoid him is filtering in PSU ... I won't be able to experiment with adding additional caps and inductors or resistors after the chassis will once be done ... So I'll have to decide before ...
The fact is - right now I have an diy version of A5 here in my room - that uses two Spragues 69.000uF/50V in PSU - and the hum can actually be heard when there is no music ...
Old 14th July 2004, 07:55 PM   #6
MikeW's Avatar
Try to do some simulations with http://www.duncanamps.com/software.html
You can try both. Start with C-R-C .33 ohms and C-L-C 1.0mH.
MikeW
Old 14th July 2004, 10:20 PM   #7
Stabist's Avatar
Thanks MikeW! I'll try and see what kind of results I will get ...
BTW - today I borrowed A5 from my friend ... To make a comparison beetwen my Zenv4 and A5 ... And to see what will I gain if/when finishing my A5 (it's a project that had status quo for last 18months )
And?
With one word - incomparable!!! WOW ... What can A5 do with my "little" floorstand babies (Focal diy) ... Incredible - allready Zen seemed quite musical amp for me - but my speakers are nominated as 5ohms ones - so altough he has 2A bias - it was noticable he would need more power to better control them ... And that's where A5 comes out!
More detailes, better bass (not so much more bass - but indeed "better bass" - better defined, etc) Soundstage - bigger ... No doubt ... And most important - with Zen at quiet listening - there like throwing a towel on speakers - so detailes are gone - but not with A5 ...
Hehe - when I start it up, I said to myself - MAX 1h of listening - then you have to study ... Khhmmm - now it's like 5h later - and I'm still listening ... I just made a 10min break to report here
"Crazy" ...
Btw - A5 has 60W/8R - but what about 4R?
Old 15th July 2004, 09:09 AM   #8
uli is offline uli  Austria
often this hum is caused by b-grade Xformers. Put your ear at the
enclosure of the amp. When you encounter a mechanical buzz,
this noise will be heard in the speakers too.
2x 69000 µF should be enough if the Xformer is ok.
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 15th July 2004, 09:21 AM   #9
Stabist's Avatar
Well, we might have problems with getting different exotic parts here - but fortunately the transformers with "made in Slovenia" mark are one of the best in the world - the transformer was custom made and is completely quiet ...
Old 15th July 2004, 09:26 AM   #10
could you provide a source for the Xformers?
TX
Uli
Mono Leach Amp Transformer mycoleptodiscus Solid State 3 30th November 2008 12:56 AM
transformer for LM3886 dual mono kit gonzalez Chip Amps 16 11th October 2008 09:55 AM
Avel Y23605 160va 2x22v Toroidal Transformer Destroyer OS. Swap Meet 1 20th March 2008 03:24 PM
FS: 2 Trafos(1000VA@2x18V) seve Swap Meet 6 6th November 2004 02:08 PM
Is this Transformer OK to use with BrianGT's dual mono kit? mattjk Chip Amps 4 22nd October 2004 11:00 AM
Page generated in 0.10726 seconds (82.55% PHP - 17.45% MySQL) with 11 queries
