#981 |
I see several members have made excellent progress in making their own board layouts. Shall I continue to drive an effort to develop a "unified" PCB for general use and mass purchasing? If there is still support for this, I would like to start by calling for all interested persons to reply and/or email me with a short message. I will compile a list of participating members and start coordinating the effort from there.
If you're interested, please indicate one of three categories: 1. people who just want to get in on the group buy at the end 2. people from 1. who also want to have input on the board design and layout 3. people who are willing to contribute their designs as a starting point, and/or can help with the layout... (tvi, BrianGT, grataku?)
- Chad. |
#982 |
Banned
I belong to group 1 , if price will be reasonable.
#983 |
I too, am a member of Group #1. I'd like to purchase a set of boards after they have been sufficiently critiqued and refined.
Eric |
#984 |
diyAudio Moderator Emeritus
I would like to try to help out and be part of group #3. I really would like to see this design mature. I realize that there are better pcb designs out there then the one that I am working on, but my current plan is just to do my own layout and have my own boards made, as I see this more of a learning experience then anything else. I don't really get much from this if I take someone else's board and slap the components from a list on it and call it done.
Should the board design stay single sided? For a group pcb order, double sided seems the way to go, since they are going to a production house anyway and double sided boards don't really cost any more $. Double sided boards give more design options: shorter traces, ground and vcc planes, and more. Looking over grataku's layout, you can see the increased symmetry that double sided pcbs can offer. On the other hand, if it stays single sided, almost anyone who knows how to etch a board can download the pics, make the films and etch their own pcbs. This also allows prototypes can be easily made and tested before organizing a group order. As for the circuit, has anyone tested both the original grey's ccs vs the revised fred ccs? As far as symmetry goes, if the traces are the same length, but don't run the same path (due to the assymetrical nature of mosfets), is this alright? -- Brian |
#985 |
diyAudio Retiree
You're a double EE student! Make like a busy bee and go test it yourself you slacker. I'll bet Professer Leach will even give you extra credit. The difference in PSRR for the voltage reference is several orders of magnitude by the way.
Youth is wasted on the young, Fred |
#986 |
I will test it myself eventually, but I don't have the parts for it now. I am gathering parts for the original posted circuit now, so I guess I will look for those parts too.
-- Brian |
#987 | |
Check my A75 boards. Although I did them 8 years ago, by hand, I still consider them a thing of beauty. The six FETs mount directly to the chassis, so heat sinks are not required. This boards had to be double sided. As to your question about symetry, don't get to concerned with it. Because of leads config on devices you will never be able to achieve perfect layout. Just try to achieve similar traces lengths and shape.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#988 |
I think single side boards are a thing of the past, if enough people are willing to do it pcb boards can be purchased for peanuts, literally.
There is no way someone etching his or her own board in the basement could be achieving the result of a commercial pcb manifacturer, not to mention the environmental clean up. I remember dumping Fe2Cl2, Fe3Cl3 and Cu2Cl2 cocktails down the drain and cleaning the flux with freon, I was 12, didn't know any better. Also remember that single face pcb without metallized holes are pretty much a one shot deal. Removal of a component more than once and the trace will peel right off. In a non-profit situation, the cost of prototyping could be included in the final price of the production boards and still come up to a board that cost 5 times less than some of the Pass clones I saw on this and other sites around. More to the point I am rapidly converging to a final design although I'll maybe sacrifice a little symmetry for ease of mounting the output transistors, I haven't decided, yet, I am getting ready to send the file out to print. This will be a prototype, no mask or component layout. It's going to cost me about $100 bucks to make a pair and that is what I am going to do if no one is interested. Of course I would like to share the $60 setup charge amongst a few "friends". One thing my Pcb won't be called is "clone". I like to think I have the original. |
#989 |
Fred,
There has been a lot of (well, a little) talk about running the CCS ground to V- for added performance. Would the be appplicable with your design as well, assuming the Current Ref FET (J505) could handle the V+ to V- voltage? |
#990 |
Wessol,
should have looked at this before emailing you. My layout allows you to do that or to go to ground or to use Grey CCS. I plan to go to -15V, so it better be possible! I think the value of the resistor may need to be doubled, that should be all. Something to test out. |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.13069 seconds (76.12% PHP - 23.88% MySQL) with 11 queries |
