Old 8th September 2002, 07:55 PM   #531
Send a message via AIM to yldouright Send a message via Yahoo to yldouright
The Saint
It depends on how you build it out. A 128W rms 8 ohm version will use 25.6V rails and have a total of 16A of bias current. If you look earlier into this thread GRollins explains how to build it out to your required size.
Nelson Pass
I have just two questions about source resistors in the Aleph-X. GRollins advised us to use 0.5V/current load on each mosfet to calculate the source resistor.
Why does he use this 0.5V value to make the calcuation when the rails are 12V? Is it because the maximum input signal is only this value?
How does GRollins calculate the source resistor power rating? It would appear that the source resistor would need to be the same as the power dissipated by each mosfet but according to the circuit this doesn't seem to be the case.
Old 8th September 2002, 08:08 PM   #532
skaara is offline skaara  Slovenia
Wont you fry the o/p fets with that high rail voltage?
Old 8th September 2002, 08:14 PM   #533
skaara
Well, it depends on how many mosfets you use and how closely you match them.
Old 8th September 2002, 08:20 PM   #534
Can you use/paralell more than one for each side in alephx?
Old 8th September 2002, 08:27 PM   #535
skaara
Exactly! Just like in the XA-200 or any other of the larger amps. Nelson parallels mosfets to keep the power dissipation per device to a reasonable amount so they don't fry up. The problem you run into with paralleling mosfets in the increasing capacitance. That's why you should choose your mosfets carefully. The reason you match closely is so each parallel device is carrying its fair share of the power burden.
Old 8th September 2002, 10:50 PM   #536
I know about capacitance, and matching, but I read somewhere that there is a problem with parlelling mosfets in aleph x, but I guess it wasnt true.
Old 8th September 2002, 11:28 PM   #537
Warp Engineer
On Holiday
AudioFreak's Avatar
Paralleling multiple output devices is one thing that we have yet to completely iron all the bugs out of in this design, it's mostly a matter of increasing the drive current and decreasing the front end impedance but this amp also seems to show stability issues under some situations so we have approached it on a case by case basis thus far.
Old 8th September 2002, 11:38 PM   #538
Has anyone thought of putting a zobel network across the two O/Ps of the Aleph X. to help with stability problems..
Values of a 10 Ohm 5 watt and 100nf ~250 AC rated Cap works well for me.
In my 1kw design it was very important that this was in place.
Anthony Holton
Aussieamplifiers
Old 8th September 2002, 11:41 PM   #539
Even from each O/P to ground would be of use as well.
Anthony
Old 9th September 2002, 02:39 PM   #540
The Saint
The issues of stability were addressed earlier in this thread. GRollins stated the circuit was rock solid and HarryHaller provided a solution to address unruly oscillations.
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.14068 seconds (71.38% PHP - 28.62% MySQL) with 11 queries
