#511 |
rtirion
I got more MPSA18's than I can use too so I'm up for trading
#512 |
The one and only
Maybe you should parallel all you've got into 2 channels
of MC preamp. I've got M1 schematic... Aaaarrrrrr irate:(pirate icon doesn't work!) |
#513 |
Nelson Pass
Ha! I can barely get my head around the power supply for this Aleph -X. I haven't even started to think preamp yet. I think I may have to build HarryHaller's Ratshack attenuator until you publish your patented current preamp and phono stage. Since I have your attention, I would like to ask what defines a choke regulated power supply and does one reduce the need for a power capacitance bank? |
#514 |
The one and only
It's just a "pi" filter, where you follow the usual capacitor
bank with a coil and a second capacitor bank for filtering. It works great, particularly if you have lots of caps. |
#515 |
Nelson Pass
hifiZen used a CRC filter where two large capacitors are presumably put in series with a power resistor. Does this alos fall into the category of a choke regulated supply even though no coil is used? |
#516 |
yldouright,
Mail me an address, and I'll snailmail you some. Use your mpsa's for the MC or something else. |
#517 |
Somewhere way back in this thread I posted some "rules of thumb" courtesy of an old copy of the Radio Amateurs Handbook. The choke input power supply was a way for them to get a higher average current from a tube rectifier without exceeding a peak value.
If the current draw dropped below a certain minimum value for the voltage output and choke size the filter would tend to act like a capacitor input supply, giving a higher output, but evidentally -- they didn't show an example-- a peakier looking waveform. I used one in my modified BoZ lineamp. Big sucker. 1.5 H, if memory serves me right. For a class A power amp drawing 1000s of mA of current, the size of the choke could be far, far smaller. Erik |
#518 |
eLarson
You posted that on page 31 but the choke does not answer my question about whether the CRC filter used by hifiZen qualifies as a "choke regulator" even though it doesn't use a coil. |
#519 |
The one and only
I suppose it would have to have a choke (inductor) to
qualify. CRC filters are a little more lossy, but they work great, in fact I've plugged them into a couple of upcoming projects. I like to use Thermistors instead of resistors, as they have a more gentle turn-on rush and can take more abuse. |
#520 |
Nelson Pass
Thanks for making the distinction between a pi filter and a choke regulator. In an earlier post, hifiZen voiced his concern about the magnetic effects of the coil in a pi filter. What should we do to minimize these effects? Another member eLarson brought to light some hifi publication that stated that there can be a smaller inductance when the current is higher. Is this just because the volt potential is lower or is some other dynamic at work here? |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 03:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 04:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 11 | 27th August 2009 03:42 PM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 12:11 PM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 08:55 AM |
| Page generated in 0.12455 seconds (72.96% PHP - 27.04% MySQL) with 11 queries |
