Old 29th August 2002, 04:32 AM   #481
Paper mache horn fabricator
carpenter's Avatar
Default safer ground plane
Why not just mask the ground plane with a thick insulating layer such as polyurethane or something similar?
John Inlow
Old 29th August 2002, 09:01 AM   #482
skaara is offline skaara  Slovenia
Are these the pcbs for grollins amp?
Old 29th August 2002, 02:15 PM   #483
carpenter's Avatar
Yes, these pcbs were designed from Grollins schematics by "tvi" and enhanced by me (carpenter). I added the Aleph off-board multi-transistor approach as well as flipping around a few components.
Please proof read before using. I'm careful, but human. I have etched myself a pcb and now have the components. After I finish my wife's home office, I'm going to put the pieces together. Until then, I have no physical proof to whether or not these circuits are layed out properly.
John Inlow
Old 29th August 2002, 02:51 PM   #484
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Sorry John, where did you say we can get a copy of your PCB?
Thank Vince
BTW- I built your heatsinks last year and they look great. I haven't had the chance to put them to work yet...maybe on the XA!
Thanks!
Old 29th August 2002, 03:09 PM   #485
carpenter's Avatar
Default pcb availability
Hi Vince,
I made the pcb myself. I attached a copy of the pcb art to a raw circuit board and pressed indentations where the pads go with a sharp pointed tool. I then added the dry transfers. I began with the pads and then layed on the circuit traces. After that came the etching. Very simple proceedure.
Thanks for the compliment regarding my chassis proceedure.
John Inlow
Old 29th August 2002, 04:00 PM   #486
John,
Just to know that I have understand well , the sense terminal is were I put the source of each mosfet.
And if can be of help: the drain of Q10 is signed two times ; one of these is the drain of Q11.
Thanks very much.
Old 29th August 2002, 04:18 PM   #487
Default Scale for the PCB layout
John,
When I open the pcb layout in photoshop, at 100% the image size is 8inch by 12inch. What is the actual dimensions of the PCB.
Thanks,
Vinay
Old 29th August 2002, 10:17 PM   #488
carpenter's Avatar
Default pcb size
The actual pcb size is 4"x6". I enlarged the drawings for clarity. I go to a photo shop to have my layout transferred to film. They do a 1/2 reduction and because of the process the detail is fantastic.
John Inlow
Old 29th August 2002, 10:32 PM   #489
carpenter's Avatar
Default nice catch stefanobilliani
This is why I'm so glad you folks are proof reading. I have made the correction to my drawings. Q10 drain (located next to R44/45 on the right hand side of the stuffing drawing) is incorrectly labeled and should be tagged Q11drain.
John Inlow
Old 29th August 2002, 10:40 PM   #490
carpenter's Avatar
Default perhaps you'll like this.....
I enhanced Grey's schematics to my liking. I added the Aleph off board concept in blue boxes. Does anyone see any flaws?
Thanks,
John Inlow
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.13078 seconds (74.41% PHP - 25.59% MySQL) with 11 queries
